Help me choosing between these two manifolds
#2 |
Drives: 2013 frs red
The merge looks nicer on the bottom one but wdik?
#3 |
Drives: JRSC BRZ SOLD
Whichever has a history of preforming the best.
#4 |
AutoX-10/10ths every run
I'm not an expert on header design, but this page looks like it has a good discussion on header design considerations: https://www.enginelabs.com/engine-te...gn-and-theory/
The main difference between the 2 headers you posted looks to be the length of the primary runners. I'd suggest researching that aspect of the header design.
| The Following 2 Users Say Thank You to whataboutbob For This Useful Post: | blsfrs (03-23-2022), Lantanafrs2 (03-19-2022) |
#5 |
Drives: 17 BRZ
From what I've seen the longer runner style header is what gives this platform better performance - Think Ace, JDL, Nameless, P&L all longer style runners giving great numbers. I'd go for the bottom set
#6 |
That's what I read, anyway, while the second one in all the dynos I found gives a great result at high RPM, but a little loss of torque under 3000 RPM, the first one seems the opposite.
Both use 45mm primaries. |
#7 |
UEL because it sounds like a true Subaru
Sent from my SM-G975U using Tapatalk |
| The Following User Says Thank You to p1l0t For This Useful Post: | Celica00 (03-24-2022) |
#8 |
The first one looks like the prev gen ace which was the best. It's a 4-2-1 while the bottom one is 4-1. The way the latter looks is it dissipates too much heat and hence all the insulation even below the oil sump.
I will go with the former not the latter. Sent from my SM-G781B using Tapatalk |
#9 | |
| The Following User Says Thank You to PulsarBeeerz For This Useful Post: | Brz-123 (03-21-2022) |
#10 |
| The Following 8 Users Say Thank You to gpvecchi For This Useful Post: | Celica00 (03-24-2022), Espi (03-19-2022), Jdmjunkie (03-19-2022), p1l0t (03-19-2022), saltywetman (03-24-2022), soundman98 (03-24-2022), venturaII (03-31-2022), x808drifter (03-19-2022) |
#11 |
#12 |
Ehm, not my taste, it sounds like an Harley...
| The Following User Says Thank You to gpvecchi For This Useful Post: | Jdmjunkie (03-19-2022) |
#13 |
| The Following User Says Thank You to p1l0t For This Useful Post: | gpvecchi (03-20-2022) |
#14 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Well the top one is HKS and it's a decent header. I'm not familiar with the bottom. But I'm sure either or will only net very little difference.
| Best manifolds (headers) to OFT - OpenFlashTablet | petermmdk | Engine, Exhaust, Transmission | 14 | 02-09-2021 03:01 PM |
| RHD/LHD Manifolds | secret.squirrel | Engine, Exhaust, Transmission | 4 | 03-11-2016 04:31 PM |
| FA20 Aftermarket Intake Manifolds | slava | Engine, Exhaust, Transmission | 13 | 03-20-2015 10:49 AM |
| EGT or O2 logging with UEL exhaust manifolds? | burdickjp | Engine, Exhaust, Transmission | 0 | 01-23-2015 04:46 PM |
| Performance manifolds | Nitro_FRS | Engine, Exhaust, Transmission | 20 | 10-17-2013 01:42 PM |
