03-11-2022, 11:58 PM | #71 | |
Drives: 2019 BRZ Sport-Tech RS
If you're set on lowering springs then the Eibach Pro Kit or RCE Yellows or tS pinks have mild drops that are not that back-breaking. |
03-12-2022, 02:40 AM | #72 | |
Drives: BRZ 2018
I've read it seats slightly higher front. |
03-12-2022, 03:35 AM | #73 | |
Drives: 2014 GT86
03-12-2022, 10:01 AM | #74 | |
This was untouched factory suspension: This was right after installing both tS springs and Bilsteins: This is today almost a year after install (but very little km because of pandemic): Looking at more and more real life photos of the tS, the rear does ride higher than you'd think - almost the same as the base model springs. So don't expect a noticeable drop from the tS springs. |
The Following User Says Thank You to N_Raged For This Useful Post: | JIM THEO (03-12-2022) |
03-12-2022, 04:25 PM | #75 | |
Drives: BRZ 2018
03-16-2022, 01:15 AM | #76 | |
Drives: 2020 BRZ Limited PP
03-17-2022, 05:38 PM | #77 | |
Rear 14¾" Keep in mind I have front SPC camber bolts @-1.9° so that'll lower the front a bit compared to stock. No camber mods in the rear. |
03-19-2022, 12:53 AM | #78 |
Thank you for that. That’s very helpful. Not what I expected at all. I’ve got new B6 on the shelf and 18’ tS springs on the way. My 2020 PP (with SPC camber bolts and same front camber) is sitting 14 1\4” front and 14 1/2” rear on stock springs and Sachs dampers. I don’t care much about lowering, but a bit of a lift is surprising.
03-19-2022, 02:41 AM | #79 |
Drives: Toyota 86
Higher gas pressure causes a bit of lift
03-19-2022, 08:14 AM | #80 |
03-19-2022, 02:41 PM | #81 | |
When I installed B6's on my Saab 9-3 it also raised the front up by a noticeable amount. So I'm guessing it's a high pressure thing. |
The Following User Says Thank You to N_Raged For This Useful Post: | Thefalls (03-20-2022) |
04-10-2022, 03:37 PM | #82 |
Drives: 2017 Toyota 86
I'm noticing the difference in the spring perch heights.
04-10-2022, 04:02 PM | #83 |
Drives: JRSC BRZ SOLD
04-10-2022, 08:29 PM | #84 |
Drives: 17 Asphalt 86
Similar Threads | ||||
Koni Yellow vs. Bilstein B6 vs. Bilstein B8 | shattered_memory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 01-04-2017 11:22 AM |
AVCS Explained | Rennmeister | Engine, Exhaust, Transmission | 3 | 03-15-2016 03:12 AM |
STX Bilstein Double Adjustable Package - Bilstein PSS with Dual Bleed Shafts | FRSport.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 02-25-2016 12:50 PM |
Ok, who has stories that can't be explained? | husker741 | Off-Topic Lounge [WARNING: NO POLITICS] | 143 | 11-26-2014 05:25 AM |
Part of the problem explained. | Suberman | CANADA | 95 | 01-28-2014 01:26 PM |
