Old 02-10-2022, 10:43 PM   #1037
15WhiteFRS
Drives: 15 FRS
Originally Posted by Compelica View Post
Internally all tunes from OFT are using the same 'internal' calibration ID, despite the number of calibrations on the OFT website - this calibration ID only differs if you're on a manual/auto, and whether its a pre-facelift/facelift. Since you are on D00C (which is a 2014 6MT on the OFT site) just take the ZA1JA01G tune and definitions from there and open it in Romraider.
Make sure to back up your tune and read the first page to figure out what to do if the flash fails for some reason.
Okay. So use the za1ja01g 13brz tune from oft
15WhiteFRS is offline   Reply With Quote
Old 02-11-2022, 08:35 PM   #1038
15WhiteFRS
Drives: 15 FRS
All tunes from OFT are using the same 'internal' calibration ID, despite the number of calibrations on the OFT website - this calibration ID only differs if you're on a manual/auto, and whether its a pre-facelift/facelift. Since you are on D00C (which is a 2014 6MT on the OFT site) just take the ZA1JA01G tune and definitions from there and open it in Romraider.
When flashing it with tacktrix what definition do I use for tacktrix
Old 02-11-2022, 09:38 PM   #1039
15WhiteFRS
Drives: 15 FRS
I think the flash went through, I used the tacktrix definitions for the oft ROM though to read it , I didn't edit it in ECU flash at all though just used it to load the ROM then flashed the ECU. The car runs and seems to drive fine but when I go to read the ECU it says requesting seed then interface closeing then error,
reading vehicle info...
[16:54:00.442] CALID : ZALJA01G
[16:54:00.444] CVN 6039568A
[16:54:00.449] VIN : JF12NAA1
[16:54:00.569] starting programming session...
[16:54:00.570]
turning off DTCs...
[16:54:00.581] turning off unnecessary communications...
[16:54:00.582] unlocking ECU..
116:54:00.582]
Requesting Seed...
[16:54:00.585] interface close
[16:54:00.586]
interface close
Old 02-12-2022, 01:04 AM   #1040
Compelica
Compelica's Avatar
Drives: 86 GT
[16:54:00.570]
turning off DTCs...
116:54:00.582]
Requesting Seed...
[16:54:00.586]
interface close
Odd never had that issue before. Try disconnecting/reconnecting tactrix and reopen Ecuflash?
DIY stuff at Compelica Works
Compelica is offline   Reply With Quote
Old 02-12-2022, 02:07 AM   #1041
15WhiteFRS
Drives: 15 FRS
Yeah I did that. Didn't work. It's so weird it happened right after I flashed my car
Did I flash it correctly? Was it ok using the tacktrix def for the oft ROM just to flash it?
Old 02-12-2022, 04:16 AM   #1042
Compelica
Compelica's Avatar
Drives: 86 GT
You dont need the def for flashing - it is only used for editing the tune.
I'm guessing here but are your Ecuflash settings correct? One would think that it wouldn't allow you to flash the tune without the proper settings but good to make sure.
Old 02-12-2022, 12:38 PM   #1043
15WhiteFRS
Drives: 15 FRS
It wouldn't let me load the tune without selecting the definition.
I think my ECU flash settings are correct
Edit. I set their cycled ignition kept trying over and over and over and over and over again then eventually it went into the and I was able to reflash it again. But then when I went to read it again after reflashing it it's doing the same thing.
It seems like it's not wanting to go into programming mode after a reflashed it the first time.
Old 02-15-2022, 09:08 PM   #1044
15WhiteFRS
Drives: 15 FRS
In case anyone was wondering. I am 90% sure it was my OBD2 port being loose and having a bad connection.
Old 02-16-2022, 02:55 AM   #1045
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Is it an actual Tactrix unit or one of the cheap ebay knockoffs? Did you buy it direct from the company?
Old 02-16-2022, 11:51 AM   #1046
15WhiteFRS
Drives: 15 FRS
I bought it from the tactrix site.
The Following User Says Thank You to 15WhiteFRS For This Useful Post:
EAGLE5 (02-16-2022)
Old 02-16-2022, 11:59 AM   #1047
EAGLE5
Dismember
EAGLE5's Avatar
Just making sure. The 3rd party ones have issues. They do have good support last I tried it.
Old 02-16-2022, 04:09 PM   #1048
15WhiteFRS
Drives: 15 FRS
I'm going to try the bending the pins inward and rubber band method
Old 02-17-2022, 09:20 AM   #1049
Compelica
Compelica's Avatar
Drives: 86 GT
Quite lucky it didn't fail on you in the midst of flashing - I use an OBD2 extender so that I don't wear out the tactrix pins. Far easier to buy a new extender than to fix intermittent issues.
Old 02-17-2022, 05:06 PM   #1050
EAGLE5
Dismember
EAGLE5's Avatar
This is why I always do a full read before I do a write, to make sure the connections are all good.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Ultramaroon (02-17-2022)
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
