Drives: Toyota GTS 86
Recommend me a race turbo setup
Hi There
I've running a water-to-air turbo kit for a while and just can't get the temps low enough for my liking. Time to move to air-to-air. I've been out of the 86 scene for a few years and lost track of which manufacturer is doing what and if there has been any stand-out winners emerge over the last few years. I'm looking for 350kW (470hp) the wheels and aim is to keep inlet air temp to 20C over ambient. All the supporting mods are there (CP Carillo internals at 12.5:1, Motec ECU, sequential gearbox, brakes, e85 Flex fuel, crash bar etc). I'm after the best engineered, highest quality option kit that just works.
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger. |
#2 |
Drives: brz 2017 hksv2
How do you expect a air-to-air intercooler to perform better than a air-to-water one?
| The Following User Says Thank You to tomm.brz For This Useful Post: | alphasaur (01-13-2022) |
#3 |
LMGTFY
Drives: 13 FRS, 91 Miata
Bigger more efficient turbo.
Water/meth injection. Both |
#4 | |
There is a 10-20C degree delta between each set of temperatures in a heat exchange process as they are not 100% efficient. Intercooler water stays say 15-20C above ambient, intake air another 15-20 above that again. A bigger, more efficient turbo is part of my question. I'm not doing water/meth injection
#5 |
and removing your air-to-water system to put an air-to-air one should cool the intake charge temp down better ?
#6 | |
Drives: RX-7 / BRZ
Welcome back. For track use and low temps it is still hard to beat P-Tuning Competition kit. The only downside is slightly more chargepiping costing a fraction of transient response. If I were ever go back to another turbo setup on this playform I'd easily pay the premium price to get away from the front mounted setups.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#7 |
Drives: 2023 BRZ
Do what @CSGMike did.
Director of Rocky Mountain 86CUP
#8 | |
That Guy
Drives: 2013 asphalt FRS MT
#9 |
Drives: 2023 BRZ
What kind of racing do you plan on doing? (i.e. drag, autocross, sprint, endurance, airstrip, etc.)
#10 |
#11 |
Drives: Track preped NA FRS
Shouldnt air to air work better than water to air? Unless im missing something, in a water to air sytem you still need to cool down that water, that in turn is used to cool down the air. Two steps = less efficiency in the overall heat exchange (loss at each step).
Sorry OP, I have no idea regarding turbo setups. I swapped to an LS because I didnt think any turbo setup would beat the reliability and power delivery of a big NA engine. |
#12 | |
The water can absorb more heat faster out of air (charge to intercooler), then air can; the delta is larger. But then, the water has to shed that heat back into the air (intercooler to ambient), which is more difficult to do, since the delta is now smaller. Double edged sword. I don't think OP's goal of 20C over ambient is very realistic at that power level, unless OP has huge money to burn on the cooling setup. It will require far more than just a bolt-on kit. |
| The Following User Says Thank You to CSG Mike For This Useful Post: | Icecreamtruk (01-25-2022) |
#13 |
at that WHP he is going to have more than just cooling issues to worry about. 470 is a pretty lofty goal and under race conditions(still don't know what type) you better have a pretty large check book.
2013 Series 10 FRS #553
| The Following User Says Thank You to jflogerzi For This Useful Post: | CSG Mike (01-26-2022) |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | Engine, Exhaust, Bolt-Ons | 8 | 10-30-2015 06:36 AM |
| FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp | PrimeMotoring | NY / NJ / CT / PA | 0 | 10-20-2014 10:48 AM |
| N/A power output potential as race setup? | rice_classic | Engine, Exhaust, Transmission | 67 | 12-17-2013 07:03 PM |
| Orido's Race Sim Setup | juliog | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 12-04-2013 01:09 PM |
