Old 01-03-2022, 10:05 AM   #19391
grumpysnapper
grumpysnapper's Avatar
Cut away enough of the "dribble" lip so that a sandwich plate can now sit where it is supposed to.... lower, more compact and making way more sense.
(no need for a riser plate and its extra seal)
grumpysnapper is offline   Reply With Quote
The Following 6 Users Say Thank You to grumpysnapper For This Useful Post:
BigTuna (01-03-2022), BrahmaBull1990 (01-03-2022), Jaden (01-04-2022), MrSkubi (01-10-2022), NoHaveMSG (01-03-2022), soundman98 (01-03-2022)
Old 01-04-2022, 10:06 PM   #19392
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
While I'm waiting for a buddy to get a night free to help me set the timing and put the timing cover back on, I took out the exhaust manifold studs, cleaned them up real nice and put them back in.
demasrv is offline   Reply With Quote
Old 01-05-2022, 05:02 PM   #19393
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Played snowplow last week and the lip didn't survive a very snowy looking chunk of ice.
At least no bumper damage!
wolffbite is offline   Reply With Quote
Old 01-05-2022, 08:00 PM   #19394
Grady
Grady's Avatar
A bumper is less expensive than that STI lip.
The Following 3 Users Say Thank You to Grady For This Useful Post:
Busybee (01-20-2022), saltywetman (01-09-2022), wolffbite (01-05-2022)
Old 01-05-2022, 08:11 PM   #19395
wolffbite
Just the tip
wolffbite's Avatar
For the part yes, but not if including painting. Bodywork/paint is really damn expensive around here.
Ah well.. I'm replacing it with a much cheaper lip because I'm sure this won't be the last time this happens.
The Following 3 Users Say Thank You to wolffbite For This Useful Post:
Busybee (01-20-2022), FLYFISHR (01-08-2022), soundman98 (01-06-2022)
Old 01-05-2022, 10:37 PM   #19396
Grady
Grady's Avatar
The first time I went off the track did the same and tore up my STI lip. I purchased a knock off and put the STI badge on it. It did not fit as well as the STI version but was only $100 instead of $500.
The Following User Says Thank You to Grady For This Useful Post:
Old 01-16-2022, 03:15 AM   #19397
Breezio
Breezio's Avatar
Drives: 2017 BRZ series.yellow
Switched to a Lithium battery for the weight savings.
Lost 31 lbs. off the front of the car.
Breezio is offline   Reply With Quote
The Following 2 Users Say Thank You to Breezio For This Useful Post:
beltax90 (01-21-2022), MrSkubi (01-20-2022)
Old 01-16-2022, 12:02 PM   #19398
Grady
Grady's Avatar
Good choice, that is my plan is to shift to these as batteries start to go out. I will stay with full size replacements though.
Old 01-16-2022, 03:00 PM   #19399
Breezio
Breezio's Avatar
If the full size replacements come down in price, I'd consider it. But these small ones are much less and it still has a similar CCA as the factory battery.
Old 01-17-2022, 06:33 PM   #19400
norcalpb
norcalpb's Avatar
Bought a used HKS header and had it powder coated, and installed Professional Awesome splitter rods on my Verus splitter.
I haven’t been stage 2 since 2018, and this setup (HKs EL header + stock OP/FP + Perrin 2.5” catback) is so much more quiet than my last setup (RevWorks UEL header + Nameless downpipe + Greddy Supreme SP catback), people are 100% right when they say an aftermarket front pipe is a real noise maker.
The Following 2 Users Say Thank You to norcalpb For This Useful Post:
beltax90 (01-21-2022), Wally86 (01-18-2022)
Old 01-18-2022, 03:41 PM   #19401
juenedgi
juenedgi's Avatar
Drives: 2018 Subaru BRZ with PP
Full lip kit installed! All from 3 different companies (Toyota 86 GR, JUN, & ZELE)
juenedgi is online now   Reply With Quote
The Following 7 Users Say Thank You to juenedgi For This Useful Post:
7 skulls (02-04-2022), beltax90 (01-21-2022), Busybee (01-20-2022), Dzmitry (01-20-2022), J95 (02-08-2022), NoHaveMSG (01-21-2022), The Red One (01-21-2022)
Old 01-20-2022, 10:37 AM   #19402
almostquick
Drives: 2017 BRZ PP
Nice setup. Can you give details on what battery hold down and fittings you went with? Also, is that the ATX12 battery?
almostquick is offline   Reply With Quote
Old 01-20-2022, 11:27 AM   #19403
sharkynrk
Drives: 2013 WRB BRZ
also interested
sharkynrk is offline   Reply With Quote
Old 01-21-2022, 01:18 AM   #19404
Breezio
Breezio's Avatar
It's the ATX20-RS
I got the mount from Checkered Sports
https://www.checkerdsports.com/colle...mount-atx20-rs
The wiring fittings are from Antigravity, but I purchased them through Checkered Sports with the mount.
https://www.checkerdsports.com/produ...pr_seq=uniform
The mounting position is decent. I drilled holes in the body and used self-tapping screws. The screws in the front are into some bracket with good thick metal. The screws in the back are in pretty thin sheet metal. Being as the whole assembly is pretty light, I think it'll be just fine.
I also put a couple strips of thin weather stripping under the battery to act as a cushion, plus the mount from Checkered Sports was a tiny bit taller then the battery.
