#43 |
Senior Citizen
Drives: Scion FR-S
off the shelf is 1.5way tuned for track/high performance street.
You can drift on it, but it wont be as aggressive as a drift spec 2way. If you are actually competing in drift, then get it tuned. If you are a street user looking to drift on occasion for fun or to practice skills, then you should be gtg. |
| The Following 2 Users Say Thank You to simpleisbest For This Useful Post: | Mykii (01-30-2023), x808drifter (01-05-2022) |
#44 |
Drives: 18 BRZ tS, 27 GRMN 86
Anyone know if the 2013- 2020 OS giken fits the 2022 model?
Thanks! |
#45 |
| The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
#46 | |
Drives: 2018 BRZ
Just curious. What’s the ETA on the osgiken diffs and are there any discounts available? I am highly considering doing this over headers and tune. |
#47 | |
Getting OS Giken LSD oil in Canada is not easy, most places here carry Motul 75W140. Thanks! |
#48 |
Noodleking
Drives: 2013 Firestorm FRS
Ah-- yes.. I ordered through 86Speed and selected the 2-way option. Support local businesses, right? Well, unfortunately, they didn't deliver and the stock option as it comes is 1.5way. Kind of annoyed by 86Speed at this point, but I can't complain about the diff. Got it installed by Kaiju Motorsports and it's been quite good on the daily streets. Haven't hit an event with it yet though, so I'll update that later on haha!
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
#49 | |
A lot of diffs are backordered, so I'd say get in line if this is the route you want to go. The majority of the incoming batch is already sold. |
#50 | |
On a OS diff, I'd recommend only OS fluid, unless you have a customized diff and your builder says otherwise. |
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | botbs (01-21-2022), x808drifter (01-24-2022) |
#51 |
Drives: 2013 frs base
Apologies if this was already posted. Very informative 12 minutes.
| The Following User Says Thank You to blsfrs For This Useful Post: | Jdmjunkie (01-22-2022) |
#52 |
Drives: '23 BRZ
OSG fluid is worth the $$$ for the smell. It's like a delightful grapefruit IPA. The only diff fluid I've encountered that doesn't stink to high heaven!
| The Following User Says Thank You to ZDan For This Useful Post: | Jdmjunkie (01-22-2022) |
#54 |
I welcome confirmation as I research installing this piece. I plan to purchase:
* 2x Differential Carrier Bearing PN# 9036650001 (G5001) * 10x Differential Ring Bolts PN# 9010111353 (38113) * 1x FRSsport Diff cover gasket Last edited by coolhandluke; 07-02-2022 at 02:05 PM. Reason: update wording |
#55 |
Drives: Toyota GT86
I found a OS Giken with the following recorded numbers, would anyone tell me if it's 1.5 or 2?
55/55 224 10-10s I want it for the road and some trackdays |
#56 | |
Drives: None
224kg of internal spring pressure 10 clutch plate pairs (20 plates total) 10s refers to preload but its relative to everything else Anyway, it's a "2 way". Whether this is a setup you actually want is a question for someone like Jon at Shaftworks https://shaftworksusa.com/
| The Following 2 Users Say Thank You to RedReplicant For This Useful Post: | Ruben_86_ (08-29-2024) |
| Tags |
| lsd, os giken |
| Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover | mav1178 | Engine, Exhaust, Transmission | 5 | 02-11-2021 01:20 PM |
| Project Mu Lugs BNIB - Racing Floating Nut & Super Lock Nut 7 | SonnyBRZ | Canada Classifieds | 0 | 02-05-2014 10:37 PM |
| Results: OS Giken SoPac Super Regional Autox Championship ... | des | Tracking / Autocross / HPDE / Drifting | 5 | 06-25-2013 11:02 PM |
| Nagisa Auto D-Lock Super Low Seat Rail | poormans_LFA | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 11-06-2012 04:35 PM |
