Old 12-24-2021, 06:40 PM   #1
RWD fun
New ECU regulations in CA?
I have a 2013 FR-S with a tuned ECU (I'll explain). My smog is coming due and I'm concerned that I will fail smog because the ECU is supposedly tuned to remove the well-documented torque. I say supposedly because it came with an ECU flasher and I was told the work had been done. Can I reflash it back to the original? Will the smog tester know or am I ok reflashing it back to the original specs?
RWD fun is offline   Reply With Quote
Old 12-24-2021, 06:45 PM   #2
p1l0t
p1l0t's Avatar
Sometimes it's easier just to buy a second ECU and keep it stock. It's like 3 plugs and 4 screws or something to swap it out.
Old 12-24-2021, 08:34 PM   #3
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
What kind of ECU flasher did it come with? Some are easier to deal with than others. All are doable.
Old 12-25-2021, 07:07 AM   #4
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I just smogged recently and passed just fine after flashing back from an Ecutek tune to the stock base tune
EndlessAzure is offline   Reply With Quote
Old 12-26-2021, 12:48 PM   #5
RWD fun
1st gen OpenFlash I believe.
Old 12-26-2021, 01:55 PM   #6
EAGLE5
Dismember
EAGLE5's Avatar
Then it is pretty easy to use that OpenFlash tablet to restore to stock. After smog, reflash the tune if you want.
I went back to stock recently. I used Tactrix, which is a bit more difficult but not hard.
The Following User Says Thank You to EAGLE5 For This Useful Post:
strat61caster (12-27-2021)
Old 12-26-2021, 08:55 PM   #7
e_lunatic
Drives: 2015 Scion FR-S
I'm so glad i'm leaving CA soon. It's so silly to have to deal with this stuff
e_lunatic is offline   Reply With Quote
The Following 4 Users Say Thank You to e_lunatic For This Useful Post:
Arthur-A (12-28-2021), BRZyJ (12-29-2021), funwheeldrive (12-27-2021), Jaden (12-29-2021)
Old 12-28-2021, 11:53 PM   #8
RWD fun
The reflash was insanely easy. Now, after reading my ECU I see there's a PO420 code. I have 3 options...
1) New catalytic converter. Yeah, no.
2) O2 bung. I wonder if the smog technician will open the hood and inspect it. I haven't had a chance to really see where it is or if it would be obvious. Does have a picture of where exactly it's located?
3) Citric acid wash. I've done this before and it works incredibly well. Cat soup anyone?
Old 12-29-2021, 10:43 AM   #9
EndlessAzure
Wheels for Brains
Do you have an aftermarket header? That's probably why the car is throwing code. I doubt the cat or the sensor has gone bad. I haven't seen many instances where that has been the case.
You won't pass a real smog visual with an aftermarket header. I recommend either buying a used one or borrowing one and swapping it.
The header itself on the FA20 engine has a catalytic converter, along with the front pipe. The only exhaust emissions sensor is located on the header; it's near the header-to-overpipe connection. In the area pictured below, you'll find a pair of twin connectors (one black and one gray); these are for the Heated O2 and AFR sensors on the header, respectively. P0420 deals with the black O2 sensor; follow the black sensor connector and wire down on the left side of the engine
Old 12-29-2021, 10:45 AM   #10
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
I left 3 years ago..
I left Cali 3 years ago, SO glad I did.
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
e_lunatic (12-30-2021)
Old 12-29-2021, 01:26 PM   #11
RWD fun
It's all stock. I wasn't aware that the headers contained the cat?
Old 12-29-2021, 09:42 PM   #12
EndlessAzure
Wheels for Brains
The car has 2 catalytic converters: one in the header, one in the front pipe.
The Following User Says Thank You to EndlessAzure For This Useful Post:
soundman98 (12-31-2021)
Old 12-29-2021, 10:08 PM   #13
jflogerzi
jflogerzi's Avatar
You will fail. Are you NA or Boost? Do you know if they used ECUTEK or Openflash to tune the ECU?
2013 Series 10 FRS #553
Old 12-31-2021, 05:16 PM   #14
RWD fun
openflash
EU Alert: Toyota GR86 on sale for just two years due to new regulations Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 8 12-04-2021 01:31 PM
Japanese Super GT’s New Regulations Previewed on Toyota GT 86 vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 20 09-16-2014 02:37 PM
New F1 regulations: significant redesign of vehicles 1Cor10:23 Off-Topic Lounge [WARNING: NO POLITICS] 22 12-07-2013 09:51 AM
2012 ARC Regulations coyote AUSTRALIA 4 12-05-2011 02:48 AM
