Old 12-21-2021, 11:29 PM   #57
bucketfoot
bucketfoot's Avatar
Drives: 2020 Toyota GT86
Originally Posted by Tokay444 View Post
You know a backfire happens in the intake manifold, right? Not sure what the cat has to do with it.
Actually they can occur in either the intake or the exhaust system (afterburn).
Now I have no clue where the ones in a tuned 86 happen as I have no interest in being that kind of an @$$hole
This post sent using 100% recycled electrons.
bucketfoot is offline   Reply With Quote
The Following User Says Thank You to bucketfoot For This Useful Post:
Tcoat (12-22-2021)
Old 12-21-2021, 11:51 PM   #58
soundman98
ProCrastinationConsultant
soundman98's Avatar
So how does the exhaust system amplify it? Because pop tunes have always been louder behind them...
Tcoat (12-22-2021)
Old 12-22-2021, 10:13 AM   #59
This ^
Backfires are any combustion outside of the cylinder where they belong. Can be on intake or exhaust side.
The most common way to get tuned backfires is by pouring excessive fuel into the exhaust so you can actually hear it.
Old 12-22-2021, 12:50 PM   #60
tomm.brz
Drives: brz 2017 hksv2
most pops and bang tunes are just ignition retard like the stock tune does on gear change, clutch pressing and sudden throttle change.... Not many touch the fueling
Also, stock cold start forces the ignition to -19 (-20 is the maximum limit hard coded into ecu, also the maximum timing which pops are put at)
And cold start also adds fuel (even if the ecu target a leaner 15.5, with the cold lot of fuel doesn't vaporize and burn) and since it also stratifies the injections, a lot of dumped fuel goes to the exhaust where it encounters the kat , pretty near the exh valves, I would say....since most of the reasons i've seen here from pops-haters is: it's not supposed to burn in the exhaust... but stock rom has plenty of moments where ignition is very retarded
I do not use them personally, but every guy I tune here in italy asks me for them , or for some type of insertable-with-a-button crackle at gear change.. and nothing wrong have happened yet
Old 12-24-2021, 04:47 PM   #61
Tokay444
No.
This ^
No.
I can't even.
Backfires are when the combustion comes BACK into the intake manifold. 99% of the time this results in catastrophic failure.
An afterfire is when your dumb pops comes AFTER the combustion chamber, in the exhaust.
Old 12-24-2021, 05:04 PM   #62
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Originally Posted by Jcas View Post
So, I feel there is a ton of controversy on whether or not this tune does truly do any damage to your brz? Basically I want to make this thread to get everyone's opinions on what it does to the car. From what i've heard it'll basically mess your cats up and basically make them useless. Possibly mess with your plugs and fowl them. Other then that I haven't much more negative effects. Anyone have experience or input?
Who uses cats these days lol jk jk
mswbrz is offline   Reply With Quote
Old 12-24-2021, 05:05 PM   #63
mswbrz
mswbrz's Avatar
Originally Posted by Grady View Post
If you want backfires you should remove both cats anyway.
Yupp , cats = no pops or backfires
Old 12-24-2021, 05:07 PM   #64
mswbrz
mswbrz's Avatar
Originally Posted by tomm.brz View Post
did someone actually get flames from exhaust while completely catless? i got only loud pops and never fire/flames
I got flames witn my Brz on delicious tune pops and bangs tune that is no longer avail ...
Old 12-24-2021, 05:09 PM   #65
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
So Backfire, Misfire and (Afterfire which just sounds incorrect) or is it pops and crackles
Old 12-24-2021, 06:32 PM   #66
soundman98
soundman98's Avatar
wtf is afterfire... just it's called backfire because it comes out the back of the car...
Old 12-24-2021, 08:19 PM   #67
Tokay444
No.
Old 12-24-2021, 08:24 PM   #68
Tokay444
Old 12-25-2021, 02:32 PM   #69
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Still waiting for someone who uses this dumbassery to explain why they do.
PetrolioBenzina is offline   Reply With Quote
The Following 2 Users Say Thank You to PetrolioBenzina For This Useful Post:
Tokay444 (12-25-2021), x808drifter (12-26-2021)
Old 12-26-2021, 04:56 AM   #70
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
To compensate for the small PP?
pops tune, tune
OFT Pops and Crackle Tune problem V4 niceman Software Tuning 8 09-16-2018 10:27 PM
OFT Backfire/Pops help DaveyBonesJones Southern California 8 08-27-2018 12:53 PM
OFT Pops and Crackle Tune just stops working after a while? stig_iv Software Tuning 12 08-21-2018 06:30 PM
Question about crackle and pop.. Qc86 Engine, Exhaust, Transmission 10 12-03-2017 02:49 PM
Exhaust crackle and pop? Kiwi Engine, Exhaust, Transmission 19 03-22-2013 04:14 PM
