Old 11-30-2021, 12:52 AM   #15
CSG Mike
CSG Mike's Avatar
Originally Posted by Dububster View Post
What I said earlier in the thread. I have pmu club racers in the front and rear. Someone sent me the fronts since you can't buy them anymore, they have probably 3-4 track days left in the front and the ones in the rear are practically new still. If you need pictures of the pad life I can send that. And Motul rbf 600 fluid
Do you have any datalogs? Without that, it'll be very difficult to help diagnose.
Old 11-30-2021, 12:54 AM   #16
Dububster
Dububster's Avatar
I don't unfortunately. What would the data logs be of exactly?
Dububster is offline   Reply With Quote
Old 11-30-2021, 03:16 PM   #17
CSG Mike
CSG Mike's Avatar
Your driving inputs and the results of those inputs.
It's a great way to both diagnose odd behaviors, as well as use as a tool for self-improvement on track.
While mostly unrelated, it also serves as a lap timer and a display for any data points you want to see in real time while on track (or anywhere else).
https://www.counterspacegarage.com/aim-solo2-dl
Old 11-30-2021, 03:54 PM   #18
Dububster
Dububster's Avatar
Oh okay. Yeah, I'll look into that for next time. I just had the Track addict app for lap times, and that isn't as detailed. Would that help better understand what I was feeling with the transmission when driving home that I mentioned too?
Old 11-30-2021, 04:11 PM   #19
CSG Mike
CSG Mike's Avatar
Depends on what the cause it but the data can eliminate some potential causes.
Old 11-30-2021, 05:27 PM   #20
Dububster
Dububster's Avatar
The more I think about it, I'm pretty sure I didn't bed the pads in properly before taking them to the track, and that probably caused the vibration I was feeling. I engaged the ABS a few times when bedding them in on the street, so I think that was the problem... hopefully it was lol.
Old 11-30-2021, 07:10 PM   #21
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I doubt it was the bedding process. Brakes are pretty robust, and can handle a few triggers of ABS during bed-in. Bad bed-in can lead to brake pulsation that is associated with the "warped rotors" feeling.
My guess is that it was just the traction control and stability kicking in. The sport mode on the FRS/BRZ has always been quite aggressive, and even more-so on the MY13-MY16 models.
If you are attempting to trail brake or have steering input while also braking, the car can kick in with stability control. Stability control can also intervene midcorner if you happen to lift off throttle or brake suddenly
With regard to your clutch, hard to say. If you have any video if your driving sessions, you can review how good your heel-toe or shifting was. Maybe you had excessive slipping on track and that caused a change in the character of your clutch afterward
EndlessAzure is offline   Reply With Quote
Old 12-01-2021, 02:25 AM   #22
Dububster
Dububster's Avatar
Okay, I appreciate your input. I can do some trial and error next time I'm at the track day with holding the traction control button instead of just doing sport mode. I've just been hesitant and still am doing that because I don't want to total my daily and find that traction control may have prevented that a few times on track.
Old 12-01-2021, 04:13 PM   #23
CSG Mike
CSG Mike's Avatar
Track insurance is a thing, if you want coverage.
While electronics are fine if you want to just sample the track, if you want to really learn to drive, they should be fully off. The more dependent you get on electronics, the more you'll need to re-learn if/when you decide to go drive without them.
Old 12-03-2021, 11:16 PM   #24
jflogerzi
jflogerzi's Avatar
He is not wrong. I recently was in the same boat as you. Trust the car feels much better in pedal dance mode. more natural, less twitchy because of the car trying to save you. Take things slow and warm up to your pace and bet you 100$ you will go faster while not having to over drive car.
2013 Series 10 FRS #553
Old 12-04-2021, 12:24 PM   #25
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
+1 on that thought.
I'm not a very experienced track guy but I autocross a lot and in both cases the extra "stuff" just gets in the way and makes everything worse. They might be useful to the inexperienced driver on public roads but in these kinds of places I want the most predictable feel possible and the electronics are just not predictable enough.
RongTurnRacing is offline   Reply With Quote
Old 12-08-2021, 05:35 PM   #26
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Just want to confirm what the others said about TC off and/or pedal dance. When I started learning it felt kinda sketchy in sport mode and I was hesitant. When I finally made the jump to TC off the car did slide more but felt much more predictable and I felt more comfortable progressing.
Next Car Recommendation Prmspen Other Vehicles & General Automotive Discussions 21 10-12-2018 07:43 PM
Front pipe recommendation to prevent rasp magicallydelicious Engine, Exhaust, Transmission 4 08-04-2016 09:43 PM
Recommendation for GTA PDR? 1Cor10:23 CANADA 12 11-08-2014 09:08 PM
Trackday GPS Recommendation milhouse Tracking / Autocross / HPDE / Drifting 12 03-24-2014 12:19 PM
Non LED recommendation for DRL boredom.is.me Cosmetic Modification (Interior/Exterior/Lighting) 13 05-11-2013 05:34 PM
