Old 11-23-2021, 08:39 PM   #1
evidence
Drives: red 2013 frs
downshifting to second
been driving my 2013 fr-s alone for a few weeks and ive had an issue when downshifting into 2nd or 1st, it just does not wanna go into gear and i try not to force it. sometimes it goes in sometimes it doesnt. and like after ive driven it at the end of the day it shifts like butter, smooth asf. any advice or knowledge would be greatly appreciated im a new driver . 40k miles btw
evidence is offline   Reply With Quote
Old 11-23-2021, 08:54 PM   #2
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Normal behavior for these cars. Before things get warmed up, learn to double clutch when you need to down shift.
Old 11-23-2021, 11:57 PM   #3
JohnH
Professional wrench
Drives: 2020 BRZ ST RS
adjust your clutch. Make sure it has minimal free play. yes it needs some, but if it has too much, the rod won't have enough authority to move the master cylinder enough.
2020 BRZ Sport Tech RS World Rally Blue
'18 TS Suspension, camber bolts, align.
Gruppe-S UEL header/overpipe
Wayne Rom Stg 2+ tune
225/45VR17 RT660s
JohnH is offline   Reply With Quote
The Following User Says Thank You to JohnH For This Useful Post:
jcw99 (11-29-2021)
Old 11-24-2021, 07:44 AM   #4
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Totally normal for 2nd to be hard to put in when the car is cold.
Also I'm not sure there's a point downshifting into 1st.
alex87f is offline   Reply With Quote
Old 11-24-2021, 03:34 PM   #5
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Two solutions that work for me. 1. a small throttle blip will help the synchros do their thing (similar to double clutching) and 2. use patience with the shifter. put light pressure on the shifter and wait for it to slide into first.
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 11-24-2021, 03:37 PM   #6
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
This is key. You apply mild pressure into the gate you want, and you can actually feel the synchro spinning up, and then the shifter falls into place.
Old 11-24-2021, 04:41 PM   #7
Ohio Enthusiast
Drives: 2018 BRZ
If you apply the throttle with the clutch depressed, you gain nothing inside the transmission, just match the speed of the flywheel to the speed of the transmission input shaft (which has sped up by the synchros) for when you release the clutch.
During double declutching you throttle blip while the shifter is in neutral and the clutch is engaged, hence you spin up the input shaft to match the speed of the output shaft times the gear ratio.
Being gentle with the gear lever does help, as well as momentarily easing the pressure and then applying it again. I rarely have issues with downshifting to 2nd, even at fairly high speeds, but to 1st is always a tough one.
Old 11-24-2021, 05:20 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Rev matching is far more important the double clutching. I never double clutch my car and have no issue getting into second at speed.
JohnH (06-23-2022)
Old 11-24-2021, 05:41 PM   #9
Ohio Enthusiast
Drives: 2018 BRZ
Again, rev-matching doesn't make any difference with how easy or difficult it is to select a gear. Feel free to try it without rev-matching and you'll see that the only difference occurs when you let go of the clutch pedal, not when you move the gear lever.
Old 11-24-2021, 06:27 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Helps a lot on my car, basically can't shift down in the cold without it. It is also easier motion wise then trying to double clutch. I have never really found that much benefit in double clutching a syncro'd transmission. Even a non syncro'd trans I have always found it easier to float and just give a light blip.
Old 11-24-2021, 06:57 PM   #11
Capt Spaulding
Persona Non Grata
while dry clutches don't have the viscous coupling that plagues wet clutches I don't think they are completely frictionless. A throttle blip will spin up the flywheel and pressure plate and, in doing so, will exert some pressure on the clutch disk and slightly unload the transmission. It's not huge and not as important as rev matching for the clutch release, but it seems to help in some situations.
I generally have no problem down shifting to first although I don't do it often at speeds above 10 mph. In my experience it rewards patience.
The Following User Says Thank You to Capt Spaulding For This Useful Post:
Ultramaroon (11-25-2021)
Old 11-24-2021, 06:57 PM   #12
Ohio Enthusiast
Drives: 2018 BRZ
Sounds like you're not talking about rev-matching but something else. Rev-matching is hitting the throttle pedal while the clutch is depressed. It only speeds up the flywheel and has no bearing on the transmission whatsoever.
Regular downshift:
  1. Depress the clutch pedal
  2. Move the gear lever to a lower gear. The synchros speed up the transmission's input shaft
  3. Release the clutch pedal. This will cause a jolt as the transmission speeds up the engine
Rev-matching downshift:
  2. Move the gear lever to a lower gear; at the same time blip the throttle pedal. The synchros speed up the transmission's input shaft
  3. Release the clutch pedal. As the engine is up to speed, there will be no jolt
(bonus - heel and toe downshifting is the same as rev-matching downshifting, just with the brake pedal applied throughout the entire process, with the throttle blip being done with the right foot while it's still pressing on the brake pedal)
Double declutching downshift:
  2. Move the gear lever to neutral
  4. Blip the throttle pedal
  5. Depress the clutch pedal
  6. Move the gear lever to a lower gear. This should be effortless and the synchros barely needing to do any speed matching (if done correctly)
  7. Release the clutch pedal. There should be no jolt, as the engine should still be up to speed from the throttle blip
Old 11-24-2021, 07:01 PM   #13
Ohio Enthusiast
Drives: 2018 BRZ
An interesting theory. I'm pretty sure it's wrong, but there's an easy test for it - while standing still with the engine on, depress the clutch pedal. Move the gear lever through the lower gears.
Then rev the engine to high RPM and move the gear lever again. If your theory is correct, there should be a noticeable difference in the movement of the lever. I'll try it out the next time I'm driving.
Old 11-24-2021, 07:11 PM   #14
Capt Spaulding
Persona Non Grata
You could also try this,
a. put the car in neutral and try pushing it.
Then,
b, put it in first and have someone depress the clutch and try pushing it. In my fairly lengthy experience a car in gear with the clutch disengaged is more difficult to push than a car in neutral.
Ohio Enthusiast (11-24-2021)
problem?
Heel Toe Downshifting henry.haden Scion FR-S / Toyota 86 GT86 General Forum 51 04-14-2020 02:11 PM
Downshifting problem from 5th to 4th n0thing Issues | Warranty | Recalls / TSB 16 01-18-2017 09:57 AM
Downshifting in Autocross smg1138 Tracking / Autocross / HPDE / Drifting 23 05-13-2016 10:41 AM
Downshifting jaime3 Scion FR-S / Toyota 86 GT86 General Forum 18 07-24-2013 10:09 PM
Downshifting AT Estey Engine, Exhaust, Transmission 20 11-14-2012 02:20 PM
