Old 11-19-2021, 04:54 PM   #15
ssj frs
ssj frs's Avatar
Drives: red, gold
I believe using the jack will cause the sealant to cure in the "compressed" state, then when you remove it, the pan will be constantly pulling away. Much better for it to cure in the state it will be used in
Sent from my ONEPLUS A5010 using Tapatalk
Will do, I appreciate it. I didnt really think about that.
Sent from my SM-G960U using Tapatalk
ssj frs is offline   Reply With Quote
Old 11-19-2021, 05:00 PM   #16
Ashikabi
Ashikabi's Avatar
Hope it works out for you
Old 11-20-2021, 01:09 AM   #17
I should have looked at the pictures on the computer vs my phone before I commented before. On the phone it looked like the bolt was sticking up through the flat part of the casting with load of clearance. Seeing it on the computer gives a whole different perspective.
I totally agree that helicoil is the way to go now.
I still don't understand the broken-ear reference. It looks like the casting is all there. Maybe another angle would help. Not sure.
Old 11-20-2021, 01:17 AM   #18
Originally Posted by ssj frs View Post
Yeah, since the ear broke off, the bolt is now fully exposed to the oil,
Oh! I think I get it. Did the casting break from forcing in a screw that was too long for the cavity?
Old 11-20-2021, 01:18 AM   #19
To long and too big by the sounds of it. Not sure how many threads are still holding actually.
Ultramaroon (11-20-2021)
Old 11-20-2021, 11:48 AM   #20
ssj frs
ssj frs's Avatar
Drives: red, gold
Its about 7.5 threads, its really sturdy as of right now. Talked to 2 Toyota techs when I went to get an oil filter and they said its fine, just to use a little bit of blue loctite and it should seal. But j went ahead and did that and put a little bit of sealant on the bottom of the bolt by the head.
The bolt is slightly larger by the oem bolts by 3 threads but I went ahead and used 2 washers and a crush washer to balance out the size.
The Following 2 Users Say Thank You to ssj frs For This Useful Post:
Tcoat (11-20-2021), Ultramaroon (11-21-2021)
Old 11-20-2021, 12:03 PM   #21
Perfect. You shouldn't have any leak issues.
ssj frs (11-20-2021)
Rocker arm broke and broke my valve cover... j0hnnykthx Issues | Warranty | Recalls / TSB 9 08-07-2020 09:12 AM
My engine broke. I really need advice DJ92 Engine, Exhaust, Transmission 61 04-25-2020 03:48 PM
Engine oil cooler install/mounting GrandSport Engine, Exhaust, Transmission 22 11-04-2018 01:28 AM
Metal cracks on engine blocks dostoyevsky Engine, Exhaust, Transmission 7 06-08-2017 11:07 PM
