Drives: 22 BRZ limited
Pedders top hats
I know about the camber/caster adjustment these offer, but are there any negatives for the stock struts running these? Will it impact the operation/life of the struts at all or am I just overthinking this?
#2 | |
Drives: 2020 BRZ Sport Tech RS
They just give that *little* bit extra that will help get things within a more performance-oriented range alignment-wise without going to a full camber/caster plate and the potential NVH those bring.
#3 |
Drives: 2016 Scion FRS Release Series 2#439
I’ve run the Pedders top mounts for two years now with no issues.
For the record my current set-up is TRD springs on Koni Yellows with camber bolts at both locations (16mm top, 14mm bottom). With these parts a -2.75 front camber is easily achieved. In fact my alignment guru stated he could get -3.5 but that would be too extreme for my 95% DD of that time. This works okay for lapping although now that I’m retired I would opt for the -3.5 had I not recently bought a set of Ohlin’s which included adjustable camber plates. I’ll install these this winter using the camber bolts for some -5 degree spring track fun. |
| The Following User Says Thank You to Muskoka800 For This Useful Post: | RToyo86 (11-25-2021) |
| Pedders Top Hats - Add camber without sacrificing wheel clearance | Anthonyc777 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 07-08-2025 01:54 PM |
| Pedders Ezfit | fujin86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 08-05-2021 05:15 PM |
| Pedders top hats and subaru camber bolts... results. | 7 skulls | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 58 | 02-01-2021 06:24 PM |
| FS: Robispec rear top hats, OEM front top hats, Scion wheel caps, OEM coin holder | MyRx | Brakes, Suspension, Chassis | 5 | 10-12-2014 02:14 PM |
| New Pedders Coilovers for the BRZ and FR-S! | RallySport Direct | Brakes, Suspension, Chassis | 4 | 06-11-2013 05:42 PM |
