#85 |
Drives: Halo 86, '19
Jfc not this oil cooling isn't necessary/tribology bullshit again.
I'll be interested to hear all about the oil temps and pressure readings for gen2 regardless and seeing how the 2.4 handles things. Biggest thing I've noticed is the straight rods instead of offset. |
#86 |
Drives: 2013 frs red
In for the lightweight pulley dyno
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | NoHaveMSG (11-22-2021) |
#87 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
With or without a lightweight flywheel?
| The Following User Says Thank You to weederr33 For This Useful Post: | NoHaveMSG (11-22-2021) |
#88 |
#89 |
Wrong. With a lightweight flywheel is the way to go!
#91 | |
Drives: brz 2017 hksv2
#92 | ||
Drives: 2022 BRZ Limited
I will most likely upgrade the radiator and/or low temp thermostat as well as a different coolant mixture (30/70 maybe) Quote:
![]() Where is the oil temp sensor located? in the oil pan?
#93 | |||
Drives: '23 BRZ
FWIW the red mark on the factory gauge is ~250F indicated, halfway between the 230F mark and the max 270F mark. I've never seen coolant temps rise beyond the ~225F (or whatever it is, could be 230?) indicated at the track, always hits same mark and holds. Honestly if I'm you, if it doesn't try to increase from there for your usage, I wouldn't worry about cooling system mods. If it ever does get to a point where it wants to climb uncontrolled, easy enough to back off and then make mods as required. Quote:
#94 | |
2022 BRZ Build 2013 FR-S Build |
#95 | ||
#96 | |
Drives: '23 BRZ
Memory is a little dodgy on this as sometimes I have the temp gauge at "normal" setting with no numbers for *F, and sometimes I have it in the alternate setting where it shows tickmarks at 150F/190F/230F/270F, and they're different scales. In any case I'd see it go up and hold in a "normal" part of the range so didn't think about it much, more keeping eye on oil temp... |
| The Following User Says Thank You to ZDan For This Useful Post: | DarkSunrise (11-16-2021) |
#97 | |
| The Following 2 Users Say Thank You to glamcem For This Useful Post: | DarkSunrise (11-16-2021), ZDan (11-16-2021) |
#98 | |
Drives: '15 BRZ RA
| Tags |
| nowforitbs |
| Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. | CSG Mike | BRZ Second-Gen (2022+) — General Topics | 25 | 11-05-2021 12:22 AM |
| Mike's 2022 BRZ on SoWS, 10 hours after taking delivery. | CSG Mike | Tracking / Autocross / HPDE / Drifting | 5 | 11-02-2021 06:57 PM |
| Mike's CS FR-S build | mikef | Member's Car Journals | 6 | 04-25-2013 10:11 AM |
| Mike @ LSD Motorsports | JDMenrique | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 04-06-2013 08:13 PM |
| Mike at Czp | _F-R-S_ | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 12-01-2012 10:01 PM |
