#71 |
friendly
Drives: 17' 86
14 seconds flat in the 1/4 is very quick for a N/A four banger. GTI, mazdaspeed 3, veloster turbo etc etc are all upper 13s low 14s.
Seek comfort in discomfort.
#72 |
Drives: '15 BRZ RA
I wouldn't say that power loses are exactly the same with 1st gen, because the engine revs faster and the rotational inertia is increased. As others said a ~15% loss is just an estimate and not the exact number of what you have on the crank.
#73 |
Drives: 2013 frs red
Theres more to acceleration than torque and horsepower. Gearing, traction etc. are a big part of it as well.
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | nikitopo (10-19-2021) |
#74 |
Drives: 2013 Scion FR-S Series 10
15% also works so well being it perfectly supports the 209 figure that Savagegeese got at the dyno. If the current car kept its 102.5 hp/ liter that means it makes 246 crank, minus 15% = 209. But yes, the losses could be lower and the actual crank could be lower too.
But only Subaru and Toyota know what is going on with the engine. Part of me wonders if they are underrating the engine now because they know in the future, emissions will require they have to tune the engine more conservatively. So they don't want to list 240hp+ and then in 2-3 years have to list it as 228. They are listing it as 228 now, knowing that will be the actual number by the end of its lifespan. Have to wait and see if the car gets slower over time. The 2022 Mustang GT just had this happen. It losses 10 hp. https://www.cnet.com/roadshow/news/2...s-regulations/ |
| The Following 5 Users Say Thank You to mazeroni For This Useful Post: | Ash_89 (10-19-2021), daiheadjai (10-19-2021), DarkSunrise (10-19-2021), Frost (10-19-2021), Pete (10-19-2021) |
#75 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#76 |
Drives: Some rust bucket
Which is why fully electric vehicles are all the rave these days. "Zero" emissions coming out of the car.
It would appear the EPA cares more about emissions coming from the tailpipe rather than production/mining of the batteries. Just speculation. |
#77 |
Drives: 22 BRZ limited
That's because the batteries aren't mined here so its not their problem. Its all the tailpipes here that are the problem.
#78 | |
Drives: 2022 GR86
You're assuming that Savagegeese's data is perfectly correct (despite being an outlier so far), and that the engine kept the same hp/liter, which it most likely didn't. Here's an alternative point of view:
| The Following User Says Thank You to timurrrr For This Useful Post: | nikitopo (10-19-2021) |
#79 |
Drives: 2018 Subaru BRZ Limited with PP
Though intriguing, this discussion is stretching too far into the numbers. Everyone will have their opinions. Don't really care about the numbers... The acceleration time and quarter mile are PLENTY impressive for this car with superior handling characteristics.
We've got a little animal coming. And for those that are into tuning, some headers at the minimum, and E85 if available, will give this baby the potential for low 13's in the quarter mile. THAT will be impressive and awesome for a modern NA 4-banger that didn't even have serious acceleration in mind. |
| The Following 4 Users Say Thank You to Dzmitry For This Useful Post: |
#80 | |
Drives: ‘22 CWP
#81 | |
TRACKBREAD
GR86 ACTUAL 0-60 and Weight
This. The real world results against known cars is enough to get me very excited about the straight line performance. Like Matt Farah said the car no longer needs an asterisk, and that is good enough for me. |
#82 |
Drives: '15 BRZ RA
Why does it say "Results above omit 1-ft rollout of 0.3 sec."? I was aware that timing for a quarter mile starts from a standstill. So is it not really a 14.0 sec , but more likely a 14.3 sec?
It looks that C&D changed this procedure back in '19: https://www.caranddriver.com/feature...hange-rollout/ I believe that it is not an apples to apples comparison with the older S2k timings. |
#83 | ||
Drives: 2022 GR86
Depends. If you go to a drag strip in the US, it will tell you you did 14.0. But 14.3 represents the "standstill to quarter mile" time better indeed. Quote:
They did however specify that they'll be re-calculating times for past vehicles. Ideally we should check each individual test for old cars to see if they've been updated, and which of the two numbers were picked for the comparison above. |
#84 |
Drives: 2022 GR86
Agree with the sentiment that real acceleration numbers, and results of real side-by-side drag races is what really matters to measure straight line performance.
Otherwise we are making some questionable assumptions (power losses are always the same %!), questionable data (some dynos show low 190's, some show 209), and then a few more layers of guestimation... The combined range of uncertainty of the results is probably almost as big as the actual change in performance. |
| PP Brembo front rotor weight, lighter-weight alternatives? | ZDan | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 02-14-2022 07:03 PM |
| GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport | Blighty | GR86 General Topics (2nd Gen 2022+ Toyota 86) | 28 | 07-18-2021 03:38 PM |
| ADVAN GT 18" Concave Face ** Actual Wheels Pics and Weight Pics | RavSpec | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 11-20-2014 11:16 PM |
| Weight Reduction vs. Weight Distribution (for track use not for drag..etc) | glamcem | Tracking / Autocross / HPDE / Drifting | 21 | 07-01-2014 11:38 AM |
| Actual Weight For FRS??? | DanPO | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 03-22-2012 05:07 PM |
