Software Tuning Discuss all software tuning topics. |
07-23-2021, 08:13 AM | #15 | |
Drives: FT86
#af3 can cause issues manily due to a lot of headers put the rear 02 sensor in a long tube and sensor doesnt sit ig gass flow so it reads incorrectly, like whwn using an 02 spacer in rear 02, but lot of headers have a similar spacer. they are not defined in the supplied oft tables but if you use the ones linked below they have #af3 tavles defined https://www.ft86club.com/forums/showthread.php?t=126180 |
08-28-2021, 05:09 PM | #16 |
Drives: Subaru BRZ 2016
Improved AFR
This is quite after the fact as the summer was a busy one.
I was able to attenuate the lean AFR pockets I observed previously by doing this: 1) putting more voltage reference points in the 3-4V range of the MAF Sensor Scaling table and rescaling the MAF, 2) modifying the Engine Load Compensation table. I did a few 2nd gear pulls and the results are shown in this graph. AFR is still not perfect but good enough to my liking. The engine loads on the other hand tell me that the AVCS tables need improvement. |
09-04-2021, 10:59 PM | #17 |
Drives: FR-S Whiteout
I started to get some pretty wild fluctuations in my commanded AFR and AFR after reverting back to factory, then reinstalling long tube header. Switching out the O2 sensor doesn't seem to effect it. It would still have these fluctuations even with brand new O2 sensors.
This behavior seems to effect the idle as well at times, causing the rpm to dip and engine to cut off. What would cause the commanded AFR behave this way if it was not a faulty O2 sensor? Misfires? Exhaust leak at the headers? Has anyone seen this kind of thing before? https://datazap.me/u/solidone/afr-fl...8076&mark=7744 https://datazap.me/u/solidone/afr-fl...7616&mark=7744
Intent > Content
cowardice is the mother of cruelty. |
09-05-2021, 08:09 AM | #18 | |
Drives: brz 2017 hksv2
disable the useless secondary o2 sensor by zero'ing the 2 af#3 tables |
09-06-2021, 03:53 PM | #19 | |
The thing is, I think this was happening even with a complete revert to stock including the original factory tune. Something is definitely not working normally. I was hoping it was the downstream O2 when I couldn't find a vacuum or exhaust leak, but unfortunately it behaved relatively the same when I swapped it out. I suppose I can give that a try and see if it changes anything.
Intent > Content
09-19-2021, 03:00 AM | #20 |
I zeroed out the AF #3 limits (CL Target compensation Limits, Correction Limits, Learning Limits), the idle no longer dips and I havent had the engine cut off coming to a stop, but I still have this odd condition where the commanded afr hangs at 15.06 during part throttle operation. It seems to happen mostly right when the engine load comes to 0.8. Before the load hits 0.8 or as soon as it goes past 0.9-1.0 engine loads, the commanded afr seems to work fine. Very strange. I'm still suspecting an exhaust leak (header gasket or small crack in headers?), but I'm not so sure that would explain the behavior in commanded AFR?
https://datazap.me/u/solidone/log-16...3888-8330-8346
Intent > Content
09-23-2021, 10:36 PM | #21 | |
Spoke too soon... stalled three times in a row coming to a stop. Then three time the idle dipped (progressively less prodounced), then back to normal again... https://datazap.me/u/solidone/stall-...3370-4828-5854 @steve99 @Kodename47 you all have any idea?
Intent > Content
cowardice is the mother of cruelty. Last edited by solidONE; 09-24-2021 at 02:13 AM. |
09-24-2021, 01:11 AM | #22 | |
Drives: FT86
Increase the values in the overun fuel resume tables say 200 rpm at the bottom end |
The Following User Says Thank You to steve99 For This Useful Post: | solidONE (09-24-2021) |
09-24-2021, 02:06 AM | #23 | |
I will try that, but its doing the same thing with completely oem hardware and the original factory A01C rom. This issue popped up right after I reverted back to stock for smog check, and stayed this way after reverting back to the previous setup minus the flex fuel. I did not reinstall the oil cooler or flex fuel system. With the long tube header, with this tune the closed loop fueling was pretty dead on, but now it run rich into the 11's:1 afr going high and wide open throttle. As well as this dip and stalling and the commanded afr issue. Same exact intake and exhaust set up.
Intent > Content
11-17-2022, 04:35 PM | #24 |
Drives: 2013 Subaru BRZ
Hey @solidONE, did you resolve this?
I am noticing that AFRs are doing something similar cruising at lower loads: https://datazap.me/u/cjwalther/16nov...4-6&zoom=5-583 I'm also A01C, running stock intake, but just threw on a ptuning 4-1. |
11-18-2022, 04:13 AM | #25 | |
LMGTFY
Drives: 13 FRS, 91 Miata
Last Activity: 09-24-2021 01:09 PM Go to someone in here that's still active. |
11-18-2022, 05:55 AM | #26 |
did u try zero'ing af#3 trims?
Similar Threads | ||||
AFR Fluctuations with turbo kit | yo.dur | Forced Induction | 15 | 01-04-2019 05:12 PM |
a/f command problem | Grip Ronin | Software Tuning | 34 | 12-18-2018 09:28 PM |
Dash command for BOOST | Flat_4_Life | Forced Induction | 5 | 01-18-2016 12:13 PM |
oil pressure fluctuations | Grip Ronin | Engine, Exhaust, Transmission | 13 | 01-19-2015 06:30 PM |
Voltage fluctuations | Andrew666 | AUSTRALIA | 7 | 03-19-2013 09:44 AM |
