#4271 |
Drives: Edelbrock SC 2015 FR-S 6MT
Agreed - the fuel up here in Canada is honestly pretty bad. That said, that was basically half the reason for installing the meth injection - we should be increasing the octane rating of the fuel fairly significantly to the point it should be almost like race gas (according to my tuner at least).
Maybe it's placebo but I'm noticing that my supercharger is almost uncomfortably warm to the touch now after an extended drive. Before the added boost and meth, I could keep my hand on top of the unit and it'd be warm but not uncomfortable. Now I don't think I could keep my hands on it for longer than a few seconds. Also, I don't know if this placebo on top of placebo, but the car seems significantly more eager and torquier when it's both cold outside and it hasn't warmed up yet. After I've been driving for a bit, it doesn't feel nearly as torquey as it did when everything was cold - I've noticed this mostly in third gear but second seems like that too.. I'm starting to wonder if that's really a heat soak issue or if I'm just imagining things. Maybe a vented hood might help? |
#4272 | |
#4273 |
#4274 |
#4275 |
Drives: 2015 FR-S
#4276 |
#4277 |
Drives: 15 BRZ, 2003 MR2, '70 Elky, 06 TBSS
#4278 |
#4279 |
I took it apart and reassembled. The runners are held on with hex socket bolts underneath and come off pretty easily.
https://photos.app.goo.gl/omA79aiukqDGgnbA6 Last edited by B T; 09-14-2021 at 04:19 PM. Reason: added photo link |
#4280 |
Do you have before/after temps? I find it unlikely that there would be a significant change, given the temperature of everything involved!
I've heard that adding a second heat exchanger can significantly drop temps though. |
#4281 | |
Just an edit, I ended up using Fel-Pro Karropak material gasket maker. Ordered a few things before settling on this. Got it off Summit. |
#4282 | |
Drives: BRZ ts
#4283 | |
The Stig's African Cousin
Drives: 2014 wrb brz
Instagram: brandonblt2
Build Thread: http://www.ft86club.com/forums/showt...86#post2219386 Flickr: brandonblt567 |
#4284 |
Drives: BRZ ts
Motherfucker. What a shit show.
I bought a used kit w v1 delicious ff and had a few hiccups. Missing some coolant tb tubing. “Oh you don’t need those, they’re for cold climate.” Took Edelbrock a couple weeks to get them to me. Had to modify my alternator. Was missing the connector to the fuel pump, had to wait a week for a new sock and connector. Just finished putting in the fuel pump and flashed the ECU. Now it won’t start. Where it previously started w oem fp and no tune. I can hear the fp run when I turn on before starting. I did a 10+ on and off hoping the fuel pressure would normalize (or get enough to start). Nothing though. Any advice on how to test this fuel pump? Swap the stock one back in? It’s been a month plus and I wholly fucking regret buying some dudes used shit. |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
