Old 08-26-2021, 02:44 PM   #995
Compelica
Compelica's Avatar
Drives: 86 GT
@steve99 @Kodename47 do you guys have the RR definition for OFT A01G that has the A/F #3 Learning Limits?
I see the table described in the def, but one of the entries is missing. @Kodename47 I suppose this link below goes to your latest defs but the A/F #3 Learning Limits is not there either.
https://www.ft86club.com/forums/show...&postcount=411
Compelica is offline   Reply With Quote
Old 08-27-2021, 03:14 AM   #996
steve99
Drives: FT86
if you have thise two #af3 parameters just zero those i think the third one in some defs is redundant or a duplicate ecutek only has 2
Compelica (08-27-2021)
Old 08-27-2021, 03:29 AM   #997
Compelica
Compelica's Avatar
Drives: 86 GT
Thanks. For some reason the A/F #3 Learning values are still coming up in OL so was wondering where was that coming from.
Old 08-28-2021, 03:55 AM   #998
steve99
Drives: FT86
not sure is that ovt v4 based tune ??
Old 08-28-2021, 04:30 AM   #999
Compelica
Compelica's Avatar
Drives: 86 GT
Tune is based on Wayne's, so yes OFT v4. Another forumer was also seeing the same issue.
https://www.ft86club.com/forums/show...41&postcount=5
Old 08-28-2021, 09:38 AM   #1000
churchx
churchx's Avatar
Drives: 2014 GT86
Compelica: I might be wrong .. but IIRC wayneroms were based on heavily reworked but OFTv3.
Old 08-28-2021, 12:12 PM   #1001
Compelica
Compelica's Avatar
Drives: 86 GT
Just checked - he did mention in his changelog on his site that his recent roms are based off V4.
Old 08-29-2021, 11:27 AM   #1002
churchx
churchx's Avatar
Drives: 2014 GT86
Compelica: then i might be reading wrong if it is as you say.
when searching on his site for "V4" in one changelog bit:
"Apr 2018 Re-generated all USDM MY12-MY16 roms from A01G/I instead of B01C/D, for compatibility with Openflash V4."
when at same Apr 2018 for Openflash Release History there is bit:
"MY12-MY16 tunes are identical to OTS 3.0."
On which base stock tune something is based on doesn't mean it's similar tuned as OFT v4.
Old 08-29-2021, 11:53 AM   #1003
Compelica
Compelica's Avatar
Drives: 86 GT
I see your point. Maybe @Wayno himself can clarify (don't see him around the forums often nowadays).
Old 09-16-2021, 04:55 PM   #1004
TeeJay.net
Drives: BRZ 2015
Does anybody know A01G hex addresses for codes that come before P0011?
The list in Romraider -> Diagnostic Trouble Codes seems to start with P0011. Codes like P000A, P000B, P000B, P000B and P0010 are nowhere to be found.
On GitHub I've found a definition file that says A01G but it's totally different from my A01G definition file I got from Wayno's website and this definition file just throws bunch of errors when I try to open my ROM.
I've also tried to just use these addresses and add them to my definition file like so
HTML Code:
<table name="(P000A) CAMSHAFT POSITION A  TIMING SLOW RESPONSE BANK 1" storageaddress="11E138" />
<table name="(P000B) CAMSHAFT POSITION B  TIMING SLOW RESPONSE BANK 1" storageaddress="11E144" />
But even with this code added they still don't appear in RomRaider.
TeeJay.net is offline   Reply With Quote
Old 09-19-2021, 10:04 PM   #1005
steve99
Drives: FT86
HTML Code:
...<table name="(P000A) CAMSHAFT POSITION A  TIMING SLOW RESPONSE BANK 1" storageaddress="11E138" /><table name="(P000B) CAMSHAFT POSITION B  TIMING SLOW RESPONSE BANK 1" storageaddress="11E144" /> ...
</div>
ok none of the romraider definitions have those codes defined
ecutek has them and its pisdible to disable those codes but they fo indicate you have a real problem and disabking those codes in tune wont fix the hardware issue
Old 09-19-2021, 11:13 PM   #1006
makinen
makinen's Avatar
Drives: Toyota 86
HTML Code:
Below lines do the trick for A01G.
HTML Code:
    <table name="(P000A) CAMSHAFT POSITION A  TIMING SLOW RESPONSE BANK 1" storageaddress="11C7C4" />
    <table name="(P000B) CAMSHAFT POSITION B  TIMING SLOW RESPONSE BANK 1" storageaddress="11C7D0" />
    <table name="(P000C) CAMSHAFT POSITION A  TIMING SLOW RESPONSE BANK 2" storageaddress="11C7DC" />
    <table name="(P000D) CAMSHAFT POSITION B  TIMING SLOW RESPONSE BANK 2" storageaddress="11C7E8" />
Name:  RomRaider v0.7.2 NOV11 2020 _ ECU Editor - NA20210919_g_polf,baseb,maf.bin 2021-09-20 오&#.jpg
And the definition file in the link you've mentioned has weird DTC addresses. I don't know why td-d left those values incorrect, but suggest to use the definition file included in the OFT distributions. Keep in mind that since OFT v4, all definitions for manuals are based on A01G.
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 09-20-2021, 10:16 AM   #1007
TeeJay.net
Drives: BRZ 2015
</div>
Absolutely, the car needs a new cam sprocket and possibly ECU changed as the service bulletin says and it will get changed soon. I was just exploring the options and found out those codes were not in the definition files unlike all other codes.
HTML Code:
Attachment 205419
Now the P000x codes show up in Romraider, thanks a lot!
The Following User Says Thank You to TeeJay.net For This Useful Post:
steve99 (09-21-2021)
Old 09-27-2021, 12:02 PM   #1008
oBradyG
Drives: 2020 Subaru BRZ AT
opening my stock bin in rom raider
Im new and trying to learn so 2 questions.
1a. So i got my stock .bin and it wont open in rom raider the CAL id is ZA1JV01D00G i get a bunch of errors trying to open it? do i need compatible DEFs for it to open?
1b. Im trying to look at the stock values cause i want my stock cold start on my stg 2 tune.. is that possible to do by copying the (Idle Speed Targets A-F, Ignition Timing Post Start, and MAF correction before start Neutral and in gear)? or will it mess things up?
Thanks!
oBradyG is offline   Reply With Quote
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
