| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#29 |
Drives: Red 2019 Subaru BRZ
I have a floor jack and 4 locking stands, and I use RAMPS!
#30 |
Drives: 2022 MT Neptune GR86 Prem.
Ramps are definitely the way to go for oil changes.
#31 |
Drives: Red 2024 GR86 Trueno
#32 |
Drives: 2013 BRZ Sport-Tech
While I tend to agree with you; having a good jack and stands is ideal for doing a large number of different jobs that ramps wouldn't necessarily be able to handle. Some people have a stricter budget and/or don't have the space to store both.
Low profile and long reach jacks seem to be getting closer and closer in price to a typical floor jack and are more useful if you're going to be driving sports cars. Low weight is nicer to use too but then cost tends to jump. |
#33 | |
Drives: 2016 Subaru BRZ
I picked one of these up a year or two ago, totally worth it. It's my go to jack now. |
#34 |
ProCrastinationConsultant
i've had ramps slide out while loading/unloading the vehicle--always a brown pants moment when the passenger side spontaneously drops with noise as you're backing down(and can't see what's happening)... was also always terrified of driving off the ends..
way easier/safer to centrally lift the car, and place some jack stands under the lift points. i usually just leave the jack in place, but loosen it slightly so it's more of a safety catch.
#35 | |
Also agree with above that there are instances where jack stands/jack is necessary (anything that requires removing a tire, for instance), but for an oil change, I just pull out of the garage, line up the ramps, roll up, position the pan, un hook the Fumoto valve (so happy that there is no stupid underbody door/panel), change the filter, close the valve, add the new oil, remove drain/pan, roll off - done! |
| The Following User Says Thank You to CincyJohn For This Useful Post: | soundman98 (08-22-2021) |
#36 |
Drives: Crapcan
You guys have cars tall enough that you can use ramps
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | soundman98 (08-27-2021), Sur (08-30-2021) |
#37 |
Well, not all ramps. But standard plastic Rhino ramps are no issue (some metal ramps have a problematic hump). Of course, I'm not lowered, but I still think you could be a little lowered and still use ramps - slammed, probably not so much. But I would have so many more things I would have to worry about before ramps (like just getting over my curb and/or over the aforementioned "lip" on my garage) if I was slammed.
#38 | |
Drives: Crapcan
| The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | Dzmitry (08-27-2021), soundman98 (08-27-2021) |
#39 |
I didn't think it was a joke (and it didn't need to be). I am sure there are issues with ramps for cars below certain heights. I don't understand the "slamming" culture as I think stock height is pretty much perfect for both performance and day to day driving. But there are lots of different parts of various car cultures I don't understand/don't like - but hey, different strokes, right?
#40 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (08-27-2021) |
#41 |
i missed the joke, but laughed anyways.
[my stock-height car didn't work with ramps] pictured, an 86 that can use ramps:
| WTB: Low profile floor jack and jack stands! | lupindub | Want-To-Buy Requests | 2 | 11-27-2015 12:03 AM |
| Custom made Jack stand supports | AlexTheGreek | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 6 | 03-04-2015 06:01 PM |
| jack stand body contact behind pincheld | tjc5268 | BRZ First-Gen (2012+) — General Topics | 2 | 04-12-2014 05:15 AM |
| Jack stand points | xxscaxx | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 09-12-2013 10:01 PM |
| Jack/stand system | Mr.Corvus | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 28 | 03-31-2013 01:02 AM |
