go_a_way1
Old 07-24-2021, 01:11 AM   #5013
jflogerzi
jflogerzi's Avatar
Originally Posted by 3k1n View Post
Hi Mike, Question for you. I have a 2017 BRZ for which I plan to autocross 5-10x a year. I'm getting an alignment soon and plan to have -4 degrees of camber in the front and -2.5 in the rear with 1/16th toe in in the rear. I plan to do a handful of track events a year, so my question for you is, will that much negative camber in the front significantly negatively impact acceleration and braking performance?
From my understanding most guys that track their BRZ/FRS don't dial in more than -3.5 degrees in the front.
Damn that's alot camber... Any particular reason for that much? I am really just curious to learn more bout the platform
2013 Series 10 FRS #553
Old 07-24-2021, 03:18 AM   #5014
jflogerzi
jflogerzi's Avatar
Any advice on scrubbing RE71rs? I am reading conflicting posts online. From what I gather warm them up a bit and then let them sit 24 hours. What kind of driving can be done to warm them up(Canyon?) and for how long before cool down?
Old 07-24-2021, 10:58 AM   #5015
TommyW
TommyW's Avatar
Drives: '13 Whiteout
For good reason. I’m not sure what type of setup would warrant -4. If you do it I’d check tire temps.
TommyW is offline   Reply With Quote
Old 07-24-2021, 06:08 PM   #5016
3k1n
3k1n's Avatar
Drives: 2017 BRZ limited PP WRC Blue
I probably should check Temps before making the jump and dialing in that much camber. If you jump onto the STX prep thread, there are a bunch of autox guys running -4 degrees. I may just end up going with -3.5 at most.
3k1n is offline   Reply With Quote
Old 07-24-2021, 06:36 PM   #5017
TommyW
TommyW's Avatar
I'd stay there. I think you'll find that's pretty damn good. STX is a totally different car. I'm guessing with the extra weight and possibly more body roll the -4 works
Old 07-24-2021, 07:08 PM   #5018
Code Monkey
Drives: Subaru BRZ
I am at -3.9 camber and this is based on tire temps. At -3.5 the outsides were still too hot.
Code Monkey is offline   Reply With Quote
The Following 2 Users Say Thank You to Code Monkey For This Useful Post:
Pat (07-25-2021), TommyW (07-24-2021)
Old 08-10-2021, 01:21 PM   #5019
trakday
Drives: 2020 Subaru BRZ PP
Hi Mike,
I'm new to 200tw tires and had some quick questions on the treadwear on my RE-71Rs (photo below, driver's front). These tires have around 500 street miles plus one track day. I'm still at stock camber, so I'm sure adjusting that will help and I plan to handle that before the next yeah day. It also looks - to my novice eye - like I let them overheat a bit. Questions:
1. Driver's front is by far the worst. Is this tire shot or can I do another track day on it?
2. If I can put another track day on them, should I have my tire shop switch the front tires?
3. If I can put them through another day, will I be able to get home on them?
In retrospect, jumping straight from the Primacy to the RE-71R was probably a bit ambitious ��
Thanks for any insight!
https://photos.app.goo.gl/1Bs99YATA7mA5Ujj8
trakday is offline   Reply With Quote
Old 08-10-2021, 02:17 PM   #5020
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by trakday View Post
Hi Mike,
Those look mint to me
Old 08-10-2021, 02:28 PM   #5021
trakday
This is where my inexperience with 200tw tires is tripping me up haha. The left side of that center strip is down to the wear bars, but the rest of the tire is mostly still fine. I just wasn't sure if that center part was going to be a problem.
Old 08-10-2021, 02:34 PM   #5022
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I didn't see that before. It is not that big of a deal, my RT660's are the same way. You should be able to run those to the cord. Though I am curious what you are running for hot pressure. Shoulders don't look that worn.
Old 08-10-2021, 06:23 PM   #5023
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Mac Struts don't help the tire wear unfortunately. You would have to run so much neg camber to use the contact patch evenly on the track, that it's impractical for daily driving and camber that's manageable for daily driving just isn't enough to evenly wear the tire on the track.
So you're left with 1 option: Rotate your tires a lot. Thanks to a quick jack, I rotate tires every session (rule limited to -3.5) but my tires do wear much faster. You could probably get away with 2-3, then rotate. Don't pay attention to the direction of the tread either because the "directional" function is for water displacement so if the track is dry - the carcass doesn't care what direction they are rotating in.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
RT-BRZ (08-10-2021)
Old 08-10-2021, 08:55 PM   #5024
Icecreamtruk
Drives: Track preped NA FRS
Just for some extra info, depending on the setup and the driver, you might need way more than past 3.5 degrees of camber up front. The reason you see so many people at around that is usually because their cars are double duty (try to daily a car at 5 degrees) or because their are limited by the setup (camber plates only get you so far). Mcpherson struts like a lot of camber. Also, equal wear does not mean fastest times, you sometimes need to sacrifice the wear and life of the tire to get the best results. For those competing, it matters.
All that to say, the sweet spot for 100-200TW tires (semi slicks or sticky street) and moderate aero (splitter, vents and wing) is in the 4 to 5 region, provided the driver can extract everything out of the car.
Icecreamtruk is offline   Reply With Quote
Old 08-10-2021, 09:26 PM   #5025
jflogerzi
jflogerzi's Avatar
Are you managing your PSI when hot? Excess wear in the middle means they are over inflated?(not 100% sure on this)
Old 08-10-2021, 11:22 PM   #5026
trakday
Yeah I hate to admit it, but I pulled a typical rookie move and forgot to take hot pressures. I was at 28psi cool, but I completely forgot to grab pressures after I came off the track.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
