Old 07-24-2021, 11:51 PM   #1
Dacfrs
Drives: Reddy Whip
Erratic Idle
2013 FRS, 110k, runs normal til you let off the gas at say, a stop sign, then idle goes to 1500 rpm for maybe 3 or 4 seconds, then dips to 500 rpm for a few seconds, before rising back to where it normally lives, 800- 950 rpm. No driveability issues, just the strange idle. No CEL's.
Dacfrs is offline   Reply With Quote
The Following User Says Thank You to Dacfrs For This Useful Post:
humfrz (07-26-2021)
Old 07-25-2021, 04:10 AM   #2
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
I am gonna guess vacuum leak or dirty throttle body.
mrha is offline   Reply With Quote
Old 07-26-2021, 02:27 AM   #3
AT or MT? (transmission)
Old 07-26-2021, 08:41 AM   #4
sygfrid
FT8Syg
sygfrid's Avatar
Drives: `12 FRS & `17 BRZ Inazuma
Inspect/clean/replace intake air filter, inspect/clean MAF sensor, check records for last spark plugs replacement
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
sygfrid is offline   Reply With Quote
Old 07-26-2021, 09:19 AM   #5
Try without AC on.
BigTuna (07-26-2021)
Old 07-27-2021, 02:07 PM   #6
sneaky_pete
Drives: MY14 86 GTS Manual Velocity Orange
this happens with a lot of early models, mine included. the stock tune on these early cars is not great. I fixed mine with Stage1 tune when my vehicle was stock and that got rid of the erratic idle. (about two weeks later when my headers arrived I went to a Stage 2+ tune).
if you are not planning on any tuning mods to your car you should be able to get your Toyota dealer to reflash your ECU to fix it https://jalopnik.com/heres-how-to-fi...ngines-5948647
sneaky_pete is offline   Reply With Quote
Erratic Oil Pressure Over 6k RPM NoHaveMSG Issues | Warranty | Recalls / TSB 9 05-26-2019 10:41 PM
AFR mostly rich, erratic at times Synack Forced Induction 49 07-07-2018 12:15 PM
OFT is flashing on and off sporadically...very erratic! chazmuska Software Tuning 3 01-16-2018 01:59 AM
Scion FRS Police Standoff Erratic Driver Arrested After Chase Speed2th Off-Topic Lounge [WARNING: NO POLITICS] 7 05-22-2016 04:38 AM
Idle dip but going FI mscamp02 Forced Induction 16 11-09-2015 04:16 PM
