#281 |
Drives: 2017 BRZ series.yellow
If you can't get A052's, then get the Nankang CR-1's, they are closer to the yoks then RE71's (which aren't even made anymore)
| The Following User Says Thank You to Breezio For This Useful Post: | Roadphantom (07-19-2021) |
#282 | |
)--Bryan
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
| The Following 2 Users Say Thank You to Autoxer62 For This Useful Post: | Roadphantom (07-19-2021), smg1138 (07-19-2021) |
#283 |
Drives: 1999 Miata
What is the consensus on the Koni/Ground Control coil-overs? I have run them on multiple Miata's and love them. I am looking to replace my FEAL 441+ coil overs as the bearing in the camber plate is making some noise and they just have always felt under-dampened (Especially on rebound).
I was thinking about trying this combo, but with a similar spring rate as my current set-up, with the Race-valving and double adjustables. https://groundcontrolstore.com/colle...nt=36342399939
DJ
1999 Miata VVT swap "Maggie" 2013 BRZ "Nancy-Drew BRZ" |
#284 |
Drives: '13 FRS - STX
+1 get used to falkens if you can't get yokes, Bridgestone are doa.
Mx5 racer, imho copy someone who's fast and friendly in your region if possible, doing something less then ordinary only works out if you've got a consistent test n tune course and plenty of time available to hone in on what works with that setup. |
| The Following User Says Thank You to strat61caster For This Useful Post: | Roadphantom (07-19-2021) |
#285 |
At the track
Drives: '14 FRS - Former e92 M3
I'll vote here for the Nankang as an alternative. I've been using them to save my precious Yokohama's and they are fine, but of course more expensive than the Falken. If cost is a factor, go Falken.
#286 |
Drives: 2013 Raven FR-S
+1 on the Falkens. Since the Yoko's were nowhere to be found, I went with a set of 660's for this season. Really enjoying them so far and have found them to perform better than expected. Only downsize is the weight, but I think it's negligible in reality. They're also much quieter than the 71R's which is nice while on the streets.
#287 | |
Drives: 1999 Miata
DJ
| The Following User Says Thank You to MX-5RACER For This Useful Post: | strat61caster (07-21-2021) |
#288 |
Drives: 2016 Scion FRS
If you don't want to copy anyone's set up, the Koni/GC setup seems to be the way to go. I searched and couldn't find a word about them.
| The Following 2 Users Say Thank You to steverife For This Useful Post: | nathand (07-22-2021), strat61caster (07-21-2021) |
#289 | |
At the track
I'm in uncharted territory over here with my Nitrons that just arrived so I understand the not wanting to necessarily copy anyone's setup, but there are of course growing pains and challenges to that... |
| The Following User Says Thank You to Kelse92 For This Useful Post: | nathand (07-22-2021) |
#290 |
Custom User Title
Approximate tire hierarchy:
Yokohama (backordered) Nankang Falken Bridgestone/BFG (conditions/surface dependent)
LOCUST 2015 FR-S (STX) and 2012 Evo X MR Instagram: LocustAutoX Sponsors:DSGPerformance Drift Office Evil Apex Racing |
| The Following 2 Users Say Thank You to Locust For This Useful Post: | Breezio (07-22-2021), racingfool (07-21-2021) |
#291 |
Drives: Miata
#292 |
Warm and dry conditions/surfaces.
| The Following User Says Thank You to steverife For This Useful Post: | racingfool (07-21-2021) |
#293 |
Drives: Miata
They like the Lincoln concrete?
#294 |
In a different car (ES MR2 Spyder) a few years back, I tested Bridgestones vs BFGs at Lincoln and a low grip local sealed asphalt site. Bracketed ABA testing, both tires in prime condition (sticker BFG's and about 20 runs on Bridgestones) and took enough runs that consistency wasn't an issue. Basically ran the same times on both tires at both sites. I liked the car a lot more on the BFG's and they paid better contingency, so that is the route I took.
Neither tire can hold a candle to the Yoks. |
| The Following 2 Users Say Thank You to steverife For This Useful Post: | Autoxer62 (07-22-2021), racingfool (07-21-2021) |
| SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 03:21 PM |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
| STX setup sharing thread (2020) | Autoxer62 | Tracking / Autocross / HPDE / Drifting | 389 | 12-29-2020 02:40 PM |
| STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 109 | 02-17-2020 12:27 PM |
| STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 12:30 PM |
