#15 |
Drives: car
I've had a couple no-starts where my engine wouldn't start on first crank when my engine was hot. I don't think it's much to worry about it besides something being out of range the moment you tried to start it again.
Injection sound is what makes up 90% of engine bay noise. You should just listen to the engine in different settings and states. I test mine every morning, doing different revs taking note of the injector and exhaust-sound feedback. I drive off down the road a couple minutes, pull over and park somewhere where I can hear the engine, listen for injector changeover. You can also get a long screwdriver or long metal probe and listen to the injectors. I use a flexible claw grabber like pic: Very easy to listen to the injector pulses. You can also listen in on the valvetrain clicking away (it is very quiet and smooth).
#16 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | 4n0m41y (07-15-2021) |
#17 |
#18 |
Drives: Crapcan
Haven't been able to get romraider to load a v4 tune on my laptop. Still looking at.
#19 |
Drives: Crapcan
Honestly, it looks okay. Could be something with the AVCS. The MAF and O2 look like they are reading fine.
@steve99
#20 | |
If it were some bad gas, that probably would have been visible in the logs as quite a bit of knock I'm guessing? Push comes to shove, I'll reflash the factory tune and take it to the dealer to see if they can find anything...although I'm like 1 of 3 of these cars in my area so the chances of them knowing what the car's suppose to run like compared to what it's running like now are slim at best. |
#21 |
Drives: Crapcan
Yes, but your IAM is going up during the log so it rules that out.
#22 |
Wait a minute. I just remembered something. Way back when I first got this thing I took it to the dealer I got it from (was a hyundai dealer someone traded this in after putting 6k miles on it for some reason) for an oil change once (cause free oil changes for a year) and they put conventional 5w-30 in it! I made it a couple miles down the road and realized something wasn't right...It was running kind of similar to how it is now, like it felt way down on power. I turned around, took straight back and said...tf? This thing should be running a full synthetic 0w-20. They changed it out, and back to normal.
So with this realization, plus if the avcs system uses oil pressure for engagement (like those solenoids on the bseries engines...just guessing)...now I'm wondering if, hell maybe I just need an oil change? Last change was about 14 months ago...BUT...BUT...hear me out....It's only been driven about 4k miles sense then. Think this full synthetic oil could have broken down to the point that it's ****n off the avcs system? Or am I connecting dots that aren't there >_<. |
| The Following User Says Thank You to 4n0m41y For This Useful Post: | humfrz (07-16-2021) |
#23 | |
| The Following User Says Thank You to humfrz For This Useful Post: | 4n0m41y (07-16-2021) |
#24 | |
Drives: FT86
Log data with oft post logs to www.datazap.me check di computer eathed with all three bolts car starts on port then switches to di and port |
#25 | |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
I'm running 5W30 synthetic right now, it's not affecting the AVCS. |
#26 | |
#27 | |
Drives: FT86
if thats a petrol oft tune its running lean at full throttle high 12 should be high 11 fuel trims look ok at idle so bit unusual but check fot inrake and exhaust leaks clean maf sensor and check di comluter bolts all three in and tight |
#28 | |
| Kicking up rock sound in rear under heavy throttle? | Blizzz | Issues | Warranty | Recalls / TSB | 15 | 09-24-2015 06:10 PM |
| Traction control kicking in on front ? | Vroomin86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-18-2015 07:26 PM |
| A/C pump kicking on and off after cold start? | Ddreder | Issues | Warranty | Recalls / TSB | 2 | 07-01-2014 11:05 AM |
| Fix or not? OCD kicking in | slowbrz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 06-20-2013 04:42 PM |
| Traction Control / Vehicle Stability VSC kicking in when not necessary? | WTF | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-15-2012 05:24 PM |
