#71 |
Drives: 2020 BRZ Limited
Sorry to bring this one back from the dead, but two questions:
1. Is this issue likely to happen if you don't swap wheels frequently? I'm going to put on some Apex 17x9s and leave them on year round. I'll torque them down between runs at the track by hand, probably 1-2 track days /mo. Probably only doing one or two removals per year for tires/pads. 2. Have the newer model years rectified this issue at all? I have a 2020 just bought earlier this year. Happy to upgrade to the ARP lugs if needed but from the above not really clear that it is necessary. |
#72 | |
Dismember
Drives: 2013 Red Scion FR-S
| The Following User Says Thank You to EAGLE5 For This Useful Post: | Lonewolf (07-15-2021) |
#73 | |
Drives: 2017 BRZ
#74 |
Bummer. Once they've been stretched, they're done. I've had zero issues but I keep them clean and have been careful from day-1.
Not saying others aren't. I've been expecting a failure but it just hasn't happened.
#75 |
Drives: 2022 GR86
I just preventively swapped all studs when it was time for me to change rotors.
I was super-careful with them, but still one of them started falling apart before that. |
#76 |
I’m surprised I haven’t had this issue yet. I’ve got a 2013 MY. I try to be careful with my studs, but I wonder if it’s because I switched out to black gorilla lugs early on.
2022 BRZ Build 2013 FR-S Build |
| The Following User Says Thank You to DarkSunrise For This Useful Post: | NLSP (07-14-2021) |
#77 |
The stubby acorn nuts don't have very deep threads.
![]() minimum aspect ratio is minimum.
#78 | |
Drives: 2017 BRZ PP, 2004 WRX
2017 here. I ended up finding a completely crossthreaded lug nut this weekend at an autocross event 3 hours away. I will admit, I was the last one to touch them, but have only rotated the wheels ONCE myself on this car this autox season. Shop installed the tires earlier this year. Last year I had the wheels off maybe 5 times max. I doubt the previous owner was swapping them. I'd say a total of 15 times on/off and the wheels studs are disintegrating all around, not just with that one. Every time you remove a lug nut, little sparkles come off and over time, you have less and less material there, which leads to crossthreading. It appears not to be fixed with the newer models. On my 2004 WRX, which I've some years swapped tires 20+ times a year, I still have all the stock studs. I've never crossthreaded or broken one. I've changed wheels in the rain, when hot after driving, in garages or out at the track/autocross. Zero issues. BRZ studs are not the same material at all IMO. I'd recommend changing them all to ARP or at least the Dorman ones. THe Dorman ones are cheaper at $50 for a full set of 20 vs $180ish for ARP normal length ones. I'll probably go the Dorman route all around myself. You can tell the ARP and Dorman ones are a different material as they are yellow-ish looking vs the stock silver color. I talked to a few autocrossers using the Dorman ones with good results.
#79 |
Drives: 2014 Ultramarine FR-S
+1 on being surprised...I have a 2014 with 92k miles. Original studs (and original TOB lol) still, using McGard Splinedrives most of its life.
#80 |
I'm more shocked that your original TOB is still going strong!
| The Following User Says Thank You to DarkSunrise For This Useful Post: | NLSP (07-15-2021) |
#81 |
Drives: 2016 Scion FRS
I don't think it is really cross threading, unless you are gunning nuts on without hand starting them. The threads get contaminated with dirt/grime/shaving or get deformed from dragging wheels across them.
I couldn't get ARP's at the time that I needed to swap, but I actually swapped out to M12x1.5 Dorman. Part number 610-414 has the same knurl diameter and basically the same length. I also started carrying a die/chaser, so I can be proactive about things if I spin a nut on and it feels bad. |
| The Following 3 Users Say Thank You to steverife For This Useful Post: |
#82 | |
ProCrastinationConsultant
and i've already lost/replaced 3 studs.
| The Following 2 Users Say Thank You to soundman98 For This Useful Post: | NoHaveMSG (07-15-2021), Ultramaroon (07-15-2021) |
#83 | |
Drives: Crapcan
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (07-15-2021) |
#84 |
| WTB WHEEL STUDS | TomShugoy | Want-To-Buy Requests | 0 | 02-08-2016 07:44 PM |
| ARP Wheel Studs | FR-S Matt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 11-09-2015 07:50 PM |
| ARP Wheel studs and 10mm hubcentric wheel spacers | S1CNSTY_SUBIE | Wheels and Tires | 3 | 04-17-2015 09:31 AM |
| WTB OEM Wheel Studs | Anthony | Want-To-Buy Requests | 8 | 08-27-2014 04:22 PM |
| Meeting with Subaru field engineer in two weeks | Subie | Issues | Warranty | Recalls / TSB | 35 | 02-25-2013 02:50 PM |
