Old 07-14-2021, 05:22 PM   #15
Originally Posted by ghostzfh View Post
Where do I start with flashing? I keep hearing about Ecutek and OFT. I'm kind of new to that stuff. How do I know which tune to flash to get a linear 1:1 pedal response?
If that is really important to you, I suggest you take your car to a tuner to have it done.
Old 07-14-2021, 06:21 PM   #16
ghostzfh
Drives: 2016 Scion FRS Halo
@humfrz Is it not practical for an enthusiast to do it?
ghostzfh is offline   Reply With Quote
Old 07-14-2021, 07:02 PM   #17
Oh, I suppose that if you really got "enthused" about it, wanted to spend the money and learn how to use the program, it would be OK -
Old 07-14-2021, 07:21 PM   #18
Turdinator
Señor Member
Turdinator's Avatar
What do you mean by this? I know describing what you want throttle response wise is hard but 1:1 tells me nothing really.
My guess is what you're experiencing is a bit of a blend of what humfrz and soundman98 have suggested. You probably have adjusted to the feel of the car and it feels normal rather than sharp to you. Also most cars also feel more doughy in hot weather. The air is less dense and you are more prone to knock. Our ECU pulls timing LONG before you will hear or feel knock. The reduced timing makes the motor feel less sharp on top of just the effect from the hot air.
A drop in filter and a tune will wake the car up a bit and make it feel sharper in general. Modifying a car is a slippery slope tho. When you see the results and how easy it can be you'll probably want more....
1974 TA22 Celica
2013 86 GT
Old 07-14-2021, 07:35 PM   #19
ghostzfh
@humfrz - Understood. But the practically of it? Does it just take way too much time to learn and a lot of money to spend for the average person? Is it synonymous with how an average person would rather take their car to a mechanic instead of learning about how cars work to swap out their transmission?
@Turdinator ...
I remember how the car operated when I first bought it, and it has changed over time. I wouldn't consider it abnormal, or normal, it just is.
Agreed. It feels slightly better in colder weather, but the issue still persists even in cold weather.
Slippery slope...how?
Old 07-14-2021, 08:47 PM   #20
Oh, I don't mean to discourage you from learning how to work on your own car. That can be a very educational and rewarding experience.
I have a timing light, vacuum gauge, dwell meter, spark plug gauge, feeler gauge, compression gauge and many years experience tuning all kinds of ICE that has a distributor and a carburetor.
However, when they took away the distributor and carburetor, I fell behind -
Now, when my machine ain't running right, I take it up to my local, trusted automotive shop and ask them to fix it - .
Wanna hear about the time I changed out the clutch in my 1937 Chevrolet pickup truck, while it was parked outside in the barnyard, up hill, at night, during the winter, below freezing, with only a coal oil light to see by, with my grandfathers rusted tools from a tractor's tool box and it was snowing and the snow was blowing ....... both ways...... and did I mention it was uphill (both ways)?
Old 07-15-2021, 12:07 AM   #21
Turdinator
Señor Member
Turdinator's Avatar
@Turdinator ...
Applying a tune is easy peasy. Easier than swapping out the manual transmission on our cars. Learning to tune yourself and dialing it in would be harder and more time consuming than swapping out the transmission.
Generally people buy an off the shelf tune and apply it via Ecutek or use OFT that comes with tunes. The overview is that OFT is cheaper but you only have tunes from the one tuner and he doesn't really support our platform anymore. The tunes he made are pretty good tho and you can freely tweak parts of the tune as you see fit. Ecutek is a product for flashing new tunes and there are hundreds of tuners worldwide that use it. Some of the popular tuners are active on these forums and have premade tunes that cover the most common mods people do on our cars. There are some good write ups on the forum if you are interested in tunes and it will save me from typing paragraphs about it all if you find one of those.
My car seems to feel best when it is around 20c outside. Do you find its less responsive below the torque dip but still pretty good above it?
It can be addictive...
1974 TA22 Celica
2013 86 GT
Old 07-15-2021, 01:43 AM   #22
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
I second the battery reset and accelerator relearn procedure as a first step.
1) Disconnect the negative terminal of your battery and leave it disconnected long enough so that the static voltage charges dissipate, a good 30 minutes should do it.
2) Reconnect the negative terminal, get in the car, turn the key to ON without starting the car and slowly depress the accelerator pedal all the way down then all the way back up at least ten times. Then turn the car back off.
3) Make sure you have 93 octane in the tank, start it up and drive it for about ten minutes normally, then from there on, drive it aggressively.
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
Old 07-15-2021, 02:32 AM   #23
Or maybe it's pulling throttle because of VSC. Before you unplug anything, do the pedal dance and see if the throttle response improves. Maybe yaw sensor is drifting out of cal. It pulls throttle way before the skid light comes on.
Old 07-15-2021, 11:59 AM   #24
ghostzfh
@Turdinator - Well, if the torque dip is around 4,500 (can't remember) then yes.
@humfrz - Definitely can picture you in the winter doing this
@FR-S2GT86 - A lot of people have suggested this....Maybe I'll try it, but I hate the fact that I'll have to do this constantly...
@Ultramaroon - Haha I read all your previous posts in the past on this problem. I love how adamant you are on the VSC thing. The only problem is that I don't want to turn off trac, vsc, and abs just to get the throttle fixed. I want to be able to fix the throttle and have those things on.
Honestly, I think the problem is due to the fact that my powertrain and engine got worn out badly from me learning how to drive manual on my car. All of those bad shifts and bad clutch engagements probably wore out the mechanical components compared to when the car was brand new. Not sure if anyone will agree with me on that.
Old 07-15-2021, 12:09 PM   #25
churchx
churchx's Avatar
Drives: 2014 GT86
From various dyno charts, most commonly torque dip is 3.5K-4K. Rarely issue for steady driving (usually 1.7-3K), and for performance driving on track (4K-redline).
Old 07-15-2021, 02:36 PM   #26
It SUCKS! haha...
This time it's really just to test. Throttle response is just fine in all but threshold cases unless "something's wrong." If you were to try it and discovered a dramatic difference when just driving normally, then I'd take it in for some quality time with Techstream for a tweak. Just a thought.
I disagree with your concern over wearing out the car. I bet it's just fine.
Old 07-15-2021, 09:36 PM   #27
soundman98
ProCrastinationConsultant
soundman98's Avatar
i seriously doubt it.
i've never beaten on a car as much as i beat on this car every time i take it for a drive. i miss a shift and grind sycro's at least once for every 2 hours of driving, and that's a very generous assumption. it's probably more.. i genuinely expected my clutch to blow out by 40k miles. at 50k, it's still working, so anything after this is bonus time.
other than a squeaky clutch fork, my car drives the same now as the day it came off the lot, only difference being that i'm more confident wielding it now than i was back then.
Old 07-15-2021, 09:58 PM   #28
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
"Wielding it"......like a sword......Ohhhh yeah.
gas pedal, sensitivity, wear
Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) BOND007_LTK DIY (Do-It-Yourself) Guides 5 05-20-2022 05:12 PM
Beastronix pedal box, Nardi Gara Sport 350mm, Velox and Cusco pedal brackets etc. captain awesome Interior Parts (Incl. Lighting) 2 04-21-2021 11:56 AM
FS: BRAND NEW Verus Throttle Spacer + Cusco Accelerator Pedal BRZ8844 Canada Classifieds 1 12-04-2020 02:43 PM
first time running Slick tires... Pedal dance or normal 5sec trac off? dejxx Tracking / Autocross / HPDE / Drifting 6 11-16-2014 05:07 PM
Long time lurker, brand new owner SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 26 09-24-2013 08:43 PM
