#15 |
#17 | |
#18 | |
Señor Member
My guess is what you're experiencing is a bit of a blend of what humfrz and soundman98 have suggested. You probably have adjusted to the feel of the car and it feels normal rather than sharp to you. Also most cars also feel more doughy in hot weather. The air is less dense and you are more prone to knock. Our ECU pulls timing LONG before you will hear or feel knock. The reduced timing makes the motor feel less sharp on top of just the effect from the hot air. A drop in filter and a tune will wake the car up a bit and make it feel sharper in general. Modifying a car is a slippery slope tho. When you see the results and how easy it can be you'll probably want more....
1974 TA22 Celica
2013 86 GT |
#19 | |||
Drives: 2016 Scion FRS Halo
@Turdinator ... Quote:
Slippery slope...how? |
#20 | |
I have a timing light, vacuum gauge, dwell meter, spark plug gauge, feeler gauge, compression gauge and many years experience tuning all kinds of ICE that has a distributor and a carburetor. However, when they took away the distributor and carburetor, I fell behind - Now, when my machine ain't running right, I take it up to my local, trusted automotive shop and ask them to fix it - .Wanna hear about the time I changed out the clutch in my 1937 Chevrolet pickup truck, while it was parked outside in the barnyard, up hill, at night, during the winter, below freezing, with only a coal oil light to see by, with my grandfathers rusted tools from a tractor's tool box and it was snowing and the snow was blowing ....... both ways...... and did I mention it was uphill (both ways)? |
#21 | ||
Señor Member
Generally people buy an off the shelf tune and apply it via Ecutek or use OFT that comes with tunes. The overview is that OFT is cheaper but you only have tunes from the one tuner and he doesn't really support our platform anymore. The tunes he made are pretty good tho and you can freely tweak parts of the tune as you see fit. Ecutek is a product for flashing new tunes and there are hundreds of tuners worldwide that use it. Some of the popular tuners are active on these forums and have premade tunes that cover the most common mods people do on our cars. There are some good write ups on the forum if you are interested in tunes and it will save me from typing paragraphs about it all if you find one of those. Quote:
It can be addictive...
1974 TA22 Celica
2013 86 GT |
#22 |
Master Collaborator
I second the battery reset and accelerator relearn procedure as a first step.
1) Disconnect the negative terminal of your battery and leave it disconnected long enough so that the static voltage charges dissipate, a good 30 minutes should do it. 2) Reconnect the negative terminal, get in the car, turn the key to ON without starting the car and slowly depress the accelerator pedal all the way down then all the way back up at least ten times. Then turn the car back off. 3) Make sure you have 93 octane in the tank, start it up and drive it for about ten minutes normally, then from there on, drive it aggressively. |
#23 |
Or maybe it's pulling throttle because of VSC. Before you unplug anything, do the pedal dance and see if the throttle response improves. Maybe yaw sensor is drifting out of cal. It pulls throttle way before the skid light comes on.
#24 |
@Turdinator - Well, if the torque dip is around 4,500 (can't remember) then yes.
@humfrz - Definitely can picture you in the winter doing this @FR-S2GT86 - A lot of people have suggested this....Maybe I'll try it, but I hate the fact that I'll have to do this constantly... @Ultramaroon - Haha I read all your previous posts in the past on this problem. I love how adamant you are on the VSC thing. The only problem is that I don't want to turn off trac, vsc, and abs just to get the throttle fixed. I want to be able to fix the throttle and have those things on. Honestly, I think the problem is due to the fact that my powertrain and engine got worn out badly from me learning how to drive manual on my car. All of those bad shifts and bad clutch engagements probably wore out the mechanical components compared to when the car was brand new. Not sure if anyone will agree with me on that. |
#25 |
Drives: 2014 GT86
From various dyno charts, most commonly torque dip is 3.5K-4K. Rarely issue for steady driving (usually 1.7-3K), and for performance driving on track (4K-redline).
#26 | |
This time it's really just to test. Throttle response is just fine in all but threshold cases unless "something's wrong." If you were to try it and discovered a dramatic difference when just driving normally, then I'd take it in for some quality time with Techstream for a tweak. Just a thought. I disagree with your concern over wearing out the car. I bet it's just fine.
#27 | |
ProCrastinationConsultant
i've never beaten on a car as much as i beat on this car every time i take it for a drive. i miss a shift and grind sycro's at least once for every 2 hours of driving, and that's a very generous assumption. it's probably more.. i genuinely expected my clutch to blow out by 40k miles. at 50k, it's still working, so anything after this is bonus time. other than a squeaky clutch fork, my car drives the same now as the day it came off the lot, only difference being that i'm more confident wielding it now than i was back then.
#28 | |
Master Collaborator
| Tags |
| gas pedal, sensitivity, wear |
| Cusco Pedal Install & Pedal Lateral Stiffening (Sideways Loose Pedal) | BOND007_LTK | DIY (Do-It-Yourself) Guides | 5 | 05-20-2022 04:12 PM |
| Beastronix pedal box, Nardi Gara Sport 350mm, Velox and Cusco pedal brackets etc. | captain awesome | Interior Parts (Incl. Lighting) | 2 | 04-21-2021 10:56 AM |
| FS: BRAND NEW Verus Throttle Spacer + Cusco Accelerator Pedal | BRZ8844 | Canada Classifieds | 1 | 12-04-2020 01:43 PM |
| first time running Slick tires... Pedal dance or normal 5sec trac off? | dejxx | Tracking / Autocross / HPDE / Drifting | 6 | 11-16-2014 04:07 PM |
| Long time lurker, brand new owner | SoCal_86 | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 09-24-2013 07:43 PM |
