Feels like DI isn't kicking in but no CEL
Uhh oh...what did I do? So this morning on my way to work I was stopped at the top of a hill, but when I went to take off forgot I was still in third...chug...chug...die, slight moment of embarrassment. When I went to fire the engine back up I noticed it took several cranks...like so many more than normal that I'm bringing it up. But it eventually turned over and off I went.
I got about half a mile or so down the road and went to turn onto another street and accelerated in first, and instantly noticed that it felt like half my power was missing. For example instead of feeling the slight pull at around 3500 or so there was nothing until around 5500 and even that felt off. Got to work, parked it, thought...eah maybe it's just in my head. This evening after work, jumped back in and nope...wasn't in my head. No power up until 5500/6000 and it just doesn't feel "right". No CEL though...which I find strange. Almost feels like it's starved for air, like something's choking it out. I pulled the air box off of it just to check and nothing at the filter level or down in the inlet pipe is obstructing airflow (for as far back as I could fit my hand (the piece that runs into the front bumper cover)). Started thinking maybe the DI system isn't engaging...but you'd think there'd be a CEL in that case. Has anyone else experienced anything like this? Have any ideas? Not sure if it's worth mentioning or not, but I have a stage 1 OFT flash on the ecu (that was done like 4 or 5 months ago with no issues). Bonus question: If I wind up taking this to the dealer should I flash back to the factory tune? I mean it's a 2013 that has no warranty left on anything. If I don't need to, I'd rather not flash it back. |
#2 |
Drives: Crapcan
Did you fill it with the wrong fuel? My car runs like absolute shit on regular 87 octane. Very sluggish.
#3 | |
If you do take it back to the dealer it should be on a factory tune or else their equipment won’t be able to access it.
#4 | |
I've got this OFT. I'm wondering if I did a datalog if that would show anything. Like if the narrowband would report accurately enough that I could tell if it's running rich or leaning out? Sadly, I just tried this (left disconnected for a good 2 minutes) and it seemed to have no effect. Appreciate the idea though. |
#5 |
Drives: Crapcan
The next thing I was going to suggest was datalog and upload to datazap.
RPM, Maf Voltage, Engine Load, Command AFR, AFR, FLKC, IAM Sent from my iPhone using Tapatalk
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | soundman98 (07-14-2021) |
#6 | |
#7 | |
Will do the log this evening and post findings (unless the condition progresses into throwing a CEL during today's commute). |
#8 |
Drives: Crapcan
Log it in a steady state, IE cruising. If there is anything wrong with the MAF or O2 it should pop out and we can see it there.
#9 |
#10 |
Drives: Crapcan
Maybe injection mode. Really, we are just trying to see what the MAF and O2 are doing.
#11 |
#12 |
Drives: Crapcan
It might just say advance multiplier. I can't remember.
#13 |
#14 |
Log successfully uploaded to datazap: https://datazap.me/u/ziltoid/001?log=0&data=1
Started from a dead stop on an on ramp, accelerated then cruised for about a mile or so, hit stoplight...waited...then did another pull and cruised for maybe 1/4mi |
| Kicking up rock sound in rear under heavy throttle? | Blizzz | Issues | Warranty | Recalls / TSB | 15 | 09-24-2015 06:10 PM |
| Traction control kicking in on front ? | Vroomin86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-18-2015 07:26 PM |
| A/C pump kicking on and off after cold start? | Ddreder | Issues | Warranty | Recalls / TSB | 2 | 07-01-2014 11:05 AM |
| Fix or not? OCD kicking in | slowbrz | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 06-20-2013 04:42 PM |
| Traction Control / Vehicle Stability VSC kicking in when not necessary? | WTF | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 08-15-2012 05:24 PM |
