Old 10-14-2017, 10:51 PM   #1
makinen
makinen's Avatar
Drives: Toyota 86
Torque spec for an oil pump housing?
Hi guys,
I'm preparing engine build.
A Reimax oil pump gear is prepared, but I can't find any torque spec or assembly instructions regarding the oil pump housing from the FR-S service manual.
Please let me know the related info.
Thanks.
Hanjo
/* Custom underbody panels and diffuser
Custom electric water pump and PWM controller
makinen is offline   Reply With Quote
Old 07-09-2021, 05:13 PM   #2
Trdfrssx
Trdfrssx's Avatar
Drives: 2013 Scion FRS
I need this info too, anyone??
Trdfrssx is offline   Reply With Quote
Old 07-09-2021, 10:43 PM   #3
Maybe you can find it here - I'm too lazy to look. Torque specs have been referenced on this forum, but I'm too lazy to search.
I asked Bubba, and he said "medium tight".
https://www.subarucar.net/sites/suba...FA20D_DOHC.pdf
Old 07-13-2021, 04:47 PM   #4
Trdfrssx
Trdfrssx's Avatar
No spec giving there either. I couldn't find the specification in the engine mechanical manual also.
I've decided on the next best option which is to loosen & tighten the bolt. A torque wrench with an angle gauge helps here or you can mark the bolt, break loose the bolt, and measure the torque value it takes to line up the marks again.
The Following User Says Thank You to Trdfrssx For This Useful Post:
Ultramaroon (07-14-2021)
Old 07-13-2021, 06:03 PM   #5
For cryen out loud - jest tighten that sucker down -
Old 07-13-2021, 08:20 PM   #6
Link to manual in my sig line
Old 07-13-2021, 08:29 PM   #7
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
It is not in there. I would measure the diameter and thread pitch of the bolt and go off generic specs for it. Most of the specs in the manual are generic anyway.
Old 07-14-2021, 12:52 PM   #8
M6x1.0 in aluminum... Same as what's spec'd for the oil pan or timing cover?
NoHaveMSG (07-14-2021)
Old 07-14-2021, 12:58 PM   #9
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
7 ft lbs sounds about right. I think that is what the 6mm on the timing cover is spec'd. I'd want to do it in 3 steps since it is a pretty thin cover and I wouldn't want to risk binding on the pump. Hand tight, 4-5 ft lbs, then final torque at 7 ft lbs.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
Trdfrssx (07-16-2021), Ultramaroon (07-14-2021)
Stock Pulley Torque Specs? (alternator, crank, and water pump) LuisAntonioSG Engine, Exhaust, Transmission 1 05-05-2017 11:51 PM
Torque spec for lug nuts wrxneffect Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 09-06-2016 09:39 PM
Torque spec for steering wheel nut? zooki Cosmetic Modification (Interior/Exterior/Lighting) 3 08-11-2015 03:14 PM
Oil pan torque spec? Astroboy Engine, Exhaust, Transmission 1 12-23-2014 02:43 PM
