Drives: 2016 Scion FRS Halo
The pipe between my muffler and resonator seems rusted on my 2016 FRS, but neither the muffler or the resonator seems to be rusting. This is strange considering that all three are connected, and that somehow the pipe in between these two things became selectively rusted.
Is this normal or is this a cause for concern? And if it's an issue, what caused it and what could I do about this? |
#2 |
Drives: Crapcan
Likely different grade of stainless made from a different vender for Subie with possibly different post treatment process. Nothing to be concerned about, it will last another 20 years.
#3 |
Drives: FRS Hot Lava
Mine was all rusty as well.
Painted with black HT paint when I took apart for front pipe change. |
#4 |
Drives: Crapcan
I just double checked, the stock rear muffler is aluminized mild steel. That is why the flange is so rusty at the joint. The mid pipe is going to pick up corrosion from heat cycling with debris stuck to it, and galvanic corrosion from being in contact with the muffler section.
#5 |
TRACKBREAD
#6 |
Drives: Crapcan
And stainless will corrode sooner if it is in contact with a ferrous metal(galvanic corrosion).
#7 |
Drives: Bone stock
Megan Racing has a replacement or you can get the remark one.
Sent from my SM-G998U using Tapatalk |
#8 |
TRACKBREAD
#9 |
galvanize this
#10 |
Drives: Crapcan
Just don't attach yourself to any dissimilar materials and you will be fine.
#11 | |
![]() you totally win
#12 |
TRACKBREAD
#13 |
#14 |
ProCrastinationConsultant
i think you need to spend more time driving your car and less time laying underneath it!
| Tags |
| exhaust, rust |
| Using a muffler as a helmholtz resonator | Ashikabi | Engine, Exhaust, Transmission | 10 | 07-16-2020 03:24 PM |
| Resonator or muffler delete? | Gatoortiz86 | Engine, Exhaust, Transmission | 10 | 01-02-2019 04:55 AM |
| Berk Muffler Delete with Resonator | BigTuna | Engine, Exhaust, Bolt-Ons | 9 | 12-05-2017 04:19 PM |
| Resonator delete? Sound with stock muffler? | Nate219BRZ | Engine, Exhaust, Transmission | 23 | 09-05-2012 07:42 PM |
