Old 07-06-2021, 06:32 PM   #1
TheRealBFKR
Drives: '18 WRB BRZ Limited w/ PP
Is stock battery AGM or wet?
Hello,
My stock battery is about done and almost three years old. Is the stock unit AGM?
Any harm in going AGM other than wallet pain?
TheRealBFKR is offline   Reply With Quote
Old 07-06-2021, 10:57 PM   #2
7 skulls
Drives: 2014 scion frs
Stock battery is a unsealed, lead acid type. Absorbent Glass Mat (AGM) is a sealed battery which uses fiberglass to hold the electrolyte like a sponge. AGM batteries can be mounted in any position and are lighter than their lead acid counterparts. No problem using an automotive AGM but if you use a battery maintainer or charger, it will have to be compatible with an AGM battery.
Back in the day, I changed the battery in my old car and watched my jeans slowly dissolve over the next week.
7 skulls is offline   Reply With Quote
Old 07-07-2021, 12:24 AM   #3
Stock battery is not sealed. It is a traditional lead-acid wet battery that requires maintenance. Info in the owner's manual.
7 skulls (07-07-2021), Tcoat (07-07-2021)
Old 07-07-2021, 08:23 AM   #4
7 skulls
My bad. Stock battery was 2 batteries ago. Current one is sealed.
The Following User Says Thank You to 7 skulls For This Useful Post:
Ultramaroon (07-07-2021)
Lightweight battery that fits the stock tray and tie down? SPCorBUST Engine, Exhaust, Transmission 40 01-11-2021 11:46 PM
Specs of the STOCK battery?? stevo_12v Electronics | Audio | NAV | Infotainment 74 10-31-2017 05:45 AM
Is the stock OEM Panasonic battery 55D23L rechargeable? ghostzfh Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 57 03-15-2017 01:33 PM
How long does stock battery last without engine on? jon2 Scion FR-S / Toyota 86 GT86 General Forum 15 03-15-2015 10:58 PM
Warning to Canadian owners about stock battery Suberman CANADA 46 03-02-2015 08:28 PM
