Old 05-31-2021, 07:45 PM   #29
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I found my Liberty Gt calipers rattled when the rubber bush on the slider pins were damaged.
Old 05-31-2021, 10:35 PM   #30
churchx
churchx's Avatar
Drives: 2014 GT86
For reference, part numbers of not that expensive caliper repair kits of replacement guide rubber bushings & caliper dust seals for twins stock brakes: front SU003-04523 , rear SU003-04098
replacement brake pad clips: front SU003-00577 , rear SU003-00627.
Regarding guide rubber bushings, i have to note that it's important what brake lube one uses on them. Some lube that is intented to use on eg. brake pad "ears"/shims or back of pads, sometimes might be not to be used with rubber, which with it may swell and then cause some sticking, resulting in possible extra brakpad drag due them not knocking back properly due not freely moving on guides. One should use right stuff at right place.
Old 06-02-2021, 02:11 PM   #31
Grady
Grady's Avatar
Originally Posted by HRTROB View Post
I have a rattling sound coming from the front when going over bumpy or uneven surfaces. It goes away with the slightest touch of the brake pedal. The pads are Ferodo DS2500, and I installed them early last year.
Upon closer inspection, it appears that the calipers have a little play - I can wiggle them with my hand and they would make a rattling sound. The pads themselves are snug on the carrier and don't have any play at all. Any idea on how to fix it? My car only has 12,000km (7,500 miles) so I don't think it is due to worn guide pins. I did not have this problem with the original pads. Help!
I would say your brakes are not rattling. What modifications have you done to the front suspension?
Old 06-10-2021, 07:53 AM   #32
Zamor86
Drives: 2013 Toyota GT 86 M/T
Originally Posted by churchx View Post
Zamor86: have you put in from stock pads those two tin inserts (anti rattle springs pointed out in post above yours) that go over "ears" of pads? IIRC Ferodo pads come without them, and obviously stock ones should be reused with them. Also have you relubed guides and those ears of pads?
Yes, I did reuse the brackets! However, they were switched left with right, so these thin metal fins were actually pointing downwards instead of upwards! My mechanic fixed that + added some additional anti-rattle mats on the back of the pads. It's something that EBC uses.
And, as for now, the rattle is gone! Still he told me that it will likely come back after a few hundred miles/km as the pad will get more and more worn out. I guess it's something you have to accept if you don't use the OEM pads with that extra spring.
Oh, and yes, the guides and the pistons are all good and lubed. I've changed all the rubbers in all calipers to new ones last year. Thanks!
Zamor86 is offline   Reply With Quote
Old 06-10-2021, 07:56 AM   #33
Zamor86
Originally Posted by Thefalls View Post
I have used TRD blue pads the don't come with the Anti rattle springs and yet didn't have the rattle. The calliper piston puts a bit of pressure on the pads so that they are resting tightly against the brake disc.
Its not like it is loosely fitted.
There are metal shims (upper and lower) in the calliper carrier where the brake pads fit (tightly).
Do you still have them in place?
With the calliper out and both brake pads fitted in the calliper carrier, try to see if there is any play.
Hey! Yes, I've reused the brackets. The calliper has no play. And the rattle is gone for now. I'll see for how long... Thank you!
The Following User Says Thank You to Zamor86 For This Useful Post:
Thefalls (06-10-2021)
DIY Brake Caliper Painting post_break DIY (Do-It-Yourself) Guides 18 07-20-2018 01:54 PM
Stoptech S/S brake lines: same between stock caliper vs big brake kit? mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-10-2016 08:14 PM
F1 brake testing. Brake caliper porn! Captain Snooze Other Vehicles & General Automotive Discussions 11 10-16-2015 01:55 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
