#15 |
Agreed. Big names seem to be well regarded by the community. Should be hard to go wrong with any of them
Sent from my ONEPLUS A5010 using Tapatalk |
#16 |
Drives: 17 Asphalt 86
Shifting to second is known to be sticky/crunchy when cold. New fluid can help but it's just the way the car is designed. Plus having a shifter directly connected to the transmission.
Just need to be smooth and consistent with inputs when cold and it usually shifts into gear fine. |
#17 | |
Drives: White 2014 brz
| The Following User Says Thank You to T_Squadrito For This Useful Post: | Cephas (04-29-2021) |
#18 | |
The install only takes 15-30 minutes if you include removing the undertray piece and take your time. You could literally do it during an oil change waiting for oil to drain out. loosen One Nut, jack up trans, grease insert, slide in, lower trans, retighten bolt/nut and done. |
#19 | |
Drives: 2017 Toyota 86 (860 SE)
(* - A hundred years ago on my '88 Chevy Beretta GT) |
#20 | |
#21 |
#22 |
Drives: Crapcan
Change your transmission fluid before doing anything else. I like Redline MT-90 in mine.
#23 |
yup. When I cycle out again I will cycle with that. Today I am just gonna run out to my local private shop and have them throw whatever GL4 they have on deck because I am probably going to cycle out again in a couple weeks to clean it out. If the engine oil says anything about the fluids in this car, I dont trust that this transmission doesn't need to have the fluids cycled at least twice
#24 | |
Drives: '13 Whiteout
#25 | ||
I'll run through my spiel again. You might regret changing fluid because of the increased noise. Consider that. This transmission has relatively small syncro clutches. I hate leaning into the gearshift. The spinny parts of the gearbox, which are all swimming in thick oil, are driven two ways.
In neutral, with clutch disengaged, once the gears all drag to a halt, they must then be spooled up again by the output shaft via the syncro clutch. That's where the difficulty is encountered. If I don't shift quickly enough, while still in neutral, I engage the clutch and spin up the gears with a blip of the throttle. Then while they are still spinning faster than the output shaft, in one motion I disengage the clutch and again go for engaging second gear. This is textbook "double clutching." It also helps with downshifting in all cases, including first gear on a roll.
#26 | |
| The Following User Says Thank You to T_Squadrito For This Useful Post: | Ultramaroon (04-29-2021) |
#27 |
Update... I pulled up to the mechanic and they refused to touch a “Subaru transmission” because Subaru has specially rated transmission fluids that they won’t touch... honestly I’m just about 96.5% sure I smell BS somewhere. It’s just in who’s part I’m not so sure about yet. I’m gonna look around for a mechanic that doesn’t care and just bring my own fluid and ask them to put it in. I can try mt90 then also. I would do it myself but I haven’t touched transmissions mich in my life and if I over fill then I’m not sure I would honestly know if it made anything any better.
| The Following 2 Users Say Thank You to T_Squadrito For This Useful Post: | Capt Spaulding (04-29-2021), Ultramaroon (04-29-2021) |
#28 | |
| The Following User Says Thank You to Ashikabi For This Useful Post: | Capt Spaulding (04-29-2021) |
| OFT - Noob Question | jRuN | Software Tuning | 4 | 08-21-2018 07:55 AM |
| Noob question about OFT | nyfries | Software Tuning | 4 | 12-09-2014 12:07 AM |
| noob question here about f.I.... | zimzum | Forced Induction | 7 | 03-06-2014 04:24 AM |
| Noob question | dro | Scion FR-S / Toyota 86 GT86 General Forum | 60 | 07-05-2013 09:33 AM |
| Noob Question.. | wWaldo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 9 | 02-21-2013 08:04 PM |
