Old 04-23-2021, 12:51 PM   #1
Shahano
Drives: LS3 Dry Sump BRZ
Fuel Pressure Drop on my LS BRZ
Hi All,
I am having a problem with a huge fuel pressure drop at Idle after having a few drift runs under the belt (50-51 psi at idle during normal operation, and after a few runs, Idle pressure drops to about 40 psi) and causes the car to run lean. I checked all various issues and changed my fuel pump (DW300C) and while the car is running perfectly well, for the first few runs, pressure drops once the fuel gets very hot.
Has anyone had this happen before? Any other ideas why the fuel pressure might drop this much?
Some background:
I am running a LS3 in the BRZ, and do not have any heat wrapping on the headers nor exhaust. Stuck fueling system other than the dw300c fuel pump.
Shahano is offline   Reply With Quote
Old 04-23-2021, 05:05 PM   #2
ls1ac
ls1ac's Avatar
Do simple first. Check for vacuum in fuel tank. Take gas cap off and listen for air getting sucked in.
How are you checking pressure? Off of fuel rail on engine?
Old 04-25-2021, 09:06 PM   #3
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
Honestly I had a similar issue and had a small fuel leak. I am sure you checked but mine was so small that it was very hard to see/find. Just a thought, check all your fuel connections.
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline   Reply With Quote
Old 04-26-2021, 10:47 AM   #4
Shahano
I touched the fuel tank (from the trunk) after a drift run, and the tank was so unbelievably hot. I will check for a leak but I don't know if that is the issue.
Old 04-26-2021, 12:44 PM   #5
ls1ac
ls1ac's Avatar
Depending on the system you are using, there is a return line to the tank. That line (if used) will return hotter fuel from the engine compartment to the tank. Check the pressure reading at the fuel rail. A bad regulator failing at temperature will also reduce the pressure.
Have you checked the pressure at the fuel rail??
Old 04-27-2021, 05:10 PM   #6
Shahano
Haven't checked the pressure at the fuel rail yet, will check it this weekend when I have some more time to work on the car.
Currently my car is a returnless system so the risk of returning hot fuel to the tank is not there for me.
Old 04-28-2021, 05:57 PM   #7
TRS
TRS's Avatar
Drives: 2013' Toyota 86 (EU spec)
You changed the fuel pump, correct? As you said, you are running return less. Nevertheless, exhaust heat can bring the fuel to pretty high temps. (in case of some GM vehicles the corresponding expansion and contraction effects of the fuel are used for leak testing of the fuel system, what excludes the necessity of a active vacuum pump as found on the 86)
Another aspect is, that unnecessary high powered fuel pumps can also add a bunch of heat.
In your case, checking for vacuum in tank is pointless on a returnless system. The system is meant to be sealed and under more or less strong vacuum (based on current operation condition) by the EVAP purge valve due to emission regulations. The vented tank as found on older cars or lawn mowers is part of automotive history meanwhile. There is even a specific test unit (EVAP canister) containing a vacuum pump which can be found on US models. CA evaporative emission regulations are very strickt and a automatic test System, checking if the Tank is still 100% sealed every few days, is mandatory there. A Tank which is not able to hold vacuum would cause DTCs on those vehicles. In other regions the system works basically in the same way, but the automatic test isnt mandatory. This means the system is still meant to be sealed, but the test unit isnt installed.
The regulator is working against the pressure in the main fuel line and doesnt care about pressure difference between ambient and in tank.
But in your case, I would check the intank pressure regulation valve first. All connections on it to begin with. (if something is leaking there, you will never find a leak looking from the outside, since leakage volume is flowing directly back into the tank) If you dont find anything there, I would replace the valve.
All this ofcourse after you made sure that realy low fuel pressure is causing your issue by measurement. If you have any wierd table changing the fueling due to high ECTs or you actualy have a overheatung issue, the fuel pressure is maybe not even your problem.
If its realy a fuel pressure issue, I would assume the regulator valve or a connection to it is reacting to the high temp.
In another application (return style system) I reached a point where the (aeromotive) fuel pump stoped working due to overtemp. I installed a cooler in the return line later.
Concerning fuel pump: I dont know the specs of your swap, but if your LS isnt FI or heavily modified, you should be fine with the OEM pump. I didnt had any starvation issues with mine. A well sealed trap door and a good working passive side pump is much more important for non FI engines (also a stock or mildly modified LS) to prevent starvation than a high flow or high pressure fuel pump. As already said, this will in the end just heat up the fuel, since the pump is cooled with fuel but generates more heat as a high power unit and also a high overflow rate at the regulator will generate additional heat. (the 86 uses a a simple on/off fuel pump signal, it is not a digital, PWM controlled pump, meaning the pump is always running at 100%)
High power/pressure pumps are something meant for FI engines with intake manifold injection (as also used on the 86 in addition to the DI), since the pump needs to work against positive MAP pressures in those applications.
BTW, is the OEM heat shield under the tank still installed or did you remove it for and reason?
TRS is offline   Reply With Quote
The Following User Says Thank You to TRS For This Useful Post:
Tomm (12-15-2024)
fuel, fuel drop, ls3, v8 brz
Fluctuating fuel pressure and fuel pump duty 1Saucyyy_brz Issues | Warranty | Recalls / TSB 4 04-27-2021 07:47 AM
Intermittent fuel pressure/signal drop (Fuel regulator prob?) Decimus Issues | Warranty | Recalls / TSB 6 03-27-2019 08:38 PM
Fuel pump assembly: Fuel pressure regulator popping out sfruski Engine, Exhaust, Transmission 2 09-15-2017 10:39 PM
Temperature drop, tire pressure check! radroach Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 11-07-2016 09:43 PM
Delicious Tuning Flex Fuel Kit Mark 1+ Fuel Pressure Safety System DeliciousTuning Software Tuning 20 06-09-2016 07:21 AM
