Old 04-18-2021, 04:02 PM   #1
Daily86
Daily86's Avatar
Drives: 2017 Toyota 86
My sub install
2017 USDM Toyota 86. Factory Pioneer head unit, stock speakers and door speaker amp.I mainly listen to my music on a USB stick. Classic rock is my preferred, but I have a mix of all genres. Like everyone else I felt the stock system was a little weak. However, at high volumes, with the bass, mids and treble set, it’s not too bad. Like the engine, ya need to keep it cranked up! Now, this is my daily driver and I do carry things in the trunk at times. So I didn’t want to big of a box. I like the fiberglass sub-woofer enclosures that Subaru and OEM Audio+ use. I found this one made of MDF on E-Bay.
https://www.ebay.com/itm/11372440561...CABEgLio_D_BwE
It’s made in Poland. It cost $219.00 with free shipping. They do make a left and right box. I bought the just the right. It took about a week to get to me in Florida. The build quality is terrific. It’s a 0.5 cubic foot box for a 10” sub. I looked for a 10’ sub that would work for this size box and came up with this Rockford Fosgate R2D4-10. Dual 4 ohm voice coils I hooked up in parallel for a 2 ohm load. Rated for 250 watts RMS at 2 ohms.
https://www.amazon.com/Rockford-Fosg...ct_top?ie=UTF8
For an amp Rockford Fosgate R2-250X1 Mono amp. 250 watts into 2 ohms. 8 awg power wire with a 50 amp fuse. To get speaker level signals to the amp I got 2 Metra harnesses, 1 male, 1 female, soldered them together and tapped off the speaker signals from the head unit, before the factory door speaker amp, and routed that to the new sub-woofer amp.
Metra adapters for amps 70-1761 & 71-1761 – Amazon.
I made a bracket for the box to attach inside the trunk to the spot that one of the push pins are located. Bought some ¼-20 clip nuts, and a threaded knob and located to the push pin spots. One by the trunk opening, and another by the back seat. Got the idea from the OEM Audio+ install videos.
Mounted the amp upside down under the brake light. Total price, a little over $500. I think it adds what was needed.
Daily86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Daily86 For This Useful Post:
FR-S2GT86 (04-18-2021), LimitedSlip (04-18-2021), paintdude258 (04-21-2021), soundman98 (04-18-2021)
Old 04-18-2021, 04:30 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
nice! how did you like the quality of the box? haven't seen that model before.
do you have a picture straight on from the back of the car? i'm curious how far it extends into the main part of the trunk
Old 04-18-2021, 05:41 PM   #3
LimitedSlip
Senior Citizen Member
LimitedSlip's Avatar
Drives: Then-1977 Celica GT Now-2017 860SE
That box looks like it's built like a brick outhouse - SOLID! I like the placement of the enclosure in the trunk. It's not hanging all the way back behind the rear axle line, stuffed away in the corner. Nice find!
LimitedSlip is offline   Reply With Quote
Old 04-18-2021, 05:51 PM   #4
Daily86
Daily86's Avatar
I think it sounds great. I'm no expert though.
The Following User Says Thank You to Daily86 For This Useful Post:
Old 04-18-2021, 05:53 PM   #5
Daily86
Daily86's Avatar
I also did something you recommended. Added a couple of caps inline with the door speakers after the factory amp. Block out some of the low bass. Two 50uF in parallel for each speaker.
Old 04-18-2021, 05:54 PM   #6
Daily86
Daily86's Avatar
Yeah, the box is built really well. Haven't seen one like it on here before. They make them for all different vehicles too.
Old 04-18-2021, 07:34 PM   #7
Daily86
Daily86's Avatar
Old 05-01-2021, 03:31 PM   #8
Daily86
Daily86's Avatar
Someone PM'd me asking how the back was attached.
CB install? Gunman Electronics | Audio | NAV | Infotainment 3 01-08-2018 07:24 PM
Fog LED install help Celigts Cosmetic Modification (Interior/Exterior/Lighting) 0 01-13-2015 02:58 PM
LCA install WallsAndFoundations Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 12-16-2014 06:47 AM
Install Day anyone? darkonion Northern California 23 06-20-2014 06:15 PM
