Old 04-09-2021, 09:15 AM   #1
Biggumzzz
Drives: Toyota 86 2014 GTS
Unhappy 2014 Auto GTS 86 gear shifting problem
Hey so my transmission seems to be having problems. Don’t know where to start looking. It does it both in drive and manual mode. First gear to second gear full throttle, the gear takes a good 2 seconds to realise it needs to shift then it gets stuck and doesnt do anything until I lift my foot, then it’ll continue climbing speed and rpm. as you can see in the video attached. No idea what the cause is. then second to third it does like a weird jump when I change to third, when I shift at heavy load. Any ideas guys? Cheers. By the way! The car shifts like butter when first started / cold. Goes crazy at warm operating temp
Biggumzzz is offline   Reply With Quote
Old 04-09-2021, 10:25 AM   #2
Have you changed the fluid at all? Really basic question I know but the difference between cold and hat shifting sounds like fluid breakdown.
Old 04-09-2021, 09:39 PM   #3
Biggumzzz
Car had a 90,000km major service, and during that service, all the fluids and oils got replaced. The problem still persisted after that service with the new fluid
The Following User Says Thank You to Biggumzzz For This Useful Post:
Tcoat (04-09-2021)
Old 04-09-2021, 10:05 PM   #4
Well that does rule out the easy one then.
Old 04-09-2021, 11:26 PM   #5
Biggumzzz
I have no idea what could be the cause of this all. At all. I’ve had someone say clutch slipping. Band failure. Bad solenoids. Everything 😂😂 I can’t get a pin point
Old 04-30-2021, 11:22 PM   #6
Biggumzzz
Problem has been found. Clutch bands were absolutely stuffed.. fluid went black after replacement in a week... definitely a dud now.. got a whole transmission replacement and the car runs like new.
Shifting Problem (Automatic) FRSure Issues | Warranty | Recalls / TSB 61 05-09-2021 08:38 PM
Please help me diagnose a shifting problem Pat Engine, Exhaust, Transmission 22 08-05-2019 04:30 PM
Problem Shifting into gears. itzryry Issues | Warranty | Recalls / TSB 6 01-25-2018 08:19 PM
Gear shifting TexasFRS Scion FR-S / Toyota 86 GT86 General Forum 31 05-11-2016 11:29 PM
Shifting from 1st-2nd gear... FRSpappa Engine, Exhaust, Transmission 13 05-24-2014 11:06 PM
