Old 03-22-2021, 12:39 PM   #15
Satarial
Drives: Subaru brz
Hello falcon_wizard,
You wrote "-The Adjustable PCV was fitted in between the Intake manifold and the AOS, instead of between the Crank Case and the AOS" but on your scheme it is installed between crankcase and aos. Am I right that between crankcase and aos must be only stock pcv valve and 3-way check valve and adj. pcv valve istalled after "out" form AOS?
Thank you.
Satarial is offline   Reply With Quote
Old 04-08-2021, 12:13 AM   #16
falcon_wizard
Drives: BRZ 2013
Thank you.
The location where the adj pcv was installed is one area that differed during actual install vice my initial design shown on the drawing. At the crankcase, there is no stock pcv valve used, just a direct connection to the AOS IN on that side, with the breather and 1psi checkvalve as failsafe should the AOS get plugged for some reason. The adj pcv is still on the same « line » but sitting « behind » the AOS vice in front of it. When connecting it directly to the engine port as initially planned, it did not reacted as well during testing and could not be calibrated properly. It also has the advantage of being protected from being plugged due to the AOS filters, and be readily accessible for making fine tuning of the idle to cruise transition screw.
As a note, I have been running the set-up for while now, with great success. I have had to tighten up (screw in) the cruise to transition screw in the adj pcv from time to time, when I felt the torque response diminishing, but that’s it. It takes litterally 30 secs to do and you can sense with the torque response right away if its right.
I found the car also performed very well with a bit lighter oil Redline 0-40 (vice RL5-40) oil for daily driving use, with essentially no oil consumption and near instant torque response, which tells me that the positive vacuum system is effective and avoid pressure buildup and oil flow issue with the turbo. When attending advanced driving clinics, RL 40WT would be used instead, however some oil consumption was seen, albeit well within expected margins I would say.
Cheers
falcon_wizard is offline   Reply With Quote
Old 04-08-2021, 02:45 PM   #17
Calum
That Guy
Drives: 2013 asphalt FRS MT
For all that money, why not just run a vacuum pump?
Old 04-08-2021, 10:40 PM   #18
falcon_wizard
Drives: BRZ 2013
The main cost of the setup is for the AOS which really is for blow by management and ensure clean air is recirculated, so that part of it would still be needed even with an active vacuum source. The vacuum source in this passive setup when in boost is the turbo, which was already there, and the manifold during idle/cruise, so a matural source of vacuum as well. the rest is the pcv valve which is not that expensive, hoses, clamps and check valves, so no big cost items there. It would likely be a even more complex setup, as the vacuum pump needs to be controlled depending of the engine load/rpm, needs to be powered, etc.
This being said It’d be interesting if anyone has had experience with an actuve setup to share... I recall reading that some high end sports car do have such setups - BMWs possibly.
Old 04-18-2021, 01:33 PM   #19
jacobe38
@slothbrz on IG
jacobe38's Avatar
Drives: Track BRZ - Supercharged
hello, your thread is very helpful to my current puzzle with my PCV system and oil consumption. I'm in the process of reading up on the links you have posted thanks a lot for sharing.
https://www.ft86club.com/forums/show...82#post3424482
this post is outlining my issues, if you had a moment to weigh in, I would really appreciate this , since you are ahead of me in the understanding of these systems.
jacobe38 is offline   Reply With Quote
Laile Under Panel ventilation radroach Scion FR-S / Toyota 86 GT86 General Forum 33 03-20-2020 11:31 AM
WTB CF hood with ventilation jflogerzi Want-To-Buy Requests 0 03-07-2020 04:07 PM
Air ventilation knob not working tazz786 Issues | Warranty | Recalls / TSB 7 12-17-2016 11:28 PM
radium crank case vent catch can nickmerronesucks Want-To-Buy Requests 0 04-05-2016 09:45 AM
WTB Short block core . Case . Crank celek Engine, Exhaust, Bolt-Ons 4 04-11-2014 10:58 AM
