Rapid clicking noise 2.5-4K rpm
Needing some help.. just got my car back from a shop (replaced engine ‘13 to ‘15) and it’s making a clicking noise from around 2500-4000 rpm and I get a faint smell of exhaust. I read online that it could be the exhaust manifold gasket, but wanted a 2nd opinion if anyone had this issue before. Also, would I need to re-tune the ecu?
I would attach a video, but there isn’t a way to on the forum. |
| The Following User Says Thank You to Jreyes96 For This Useful Post: | humfrz (04-08-2021) |
#2 | |
As far as the ECU, as long as they used the one that came with the new engine and the car is running good, I reckon it's good to go.
| The Following User Says Thank You to humfrz For This Useful Post: | DarkPira7e (04-08-2021) |
#3 |
Rust bucket enthusiast
Does it do it when you rev sitting still? Or more prominent under load while driving?
#4 | |
#5 |
#6 |
Drives: brz 2017 hksv2
post logs...
#7 |
Don't drive it any more. Have towed back to the shop. The less mileage the better off you will be.
2013 Series 10 FRS #553
#8 |
Gentleman/scholar
Drives: 13 FRS, 89 RX 3dr, 00 gf8, 73 F250,
Clicking 2.5-4K is much more extensive than I’ve dealt with, however......
All of the 4 cylinder Subaru’s I own, all of the 4 cylinder Subaru’s I’ve driven, and all of the 4 cylinder Subaru’s I’ve worked on, twerk and click mildly between 1.5-2.5k depending on which specific engine designation it is. It’s that good old Subaru engine noise, separate from the exhaust noise. (Torsional imbalance? Harmonic resonance? Idk...) So, in the event that it checks out with a clean bill of health, this is just something we deal with.
Just glassin
73 F250 CSR 390 4otf in metallic sativa; 89 RX turbo fastback hs 1/2600 never ending project; 00 Impreza L 2.2 with a bazillion miles; 13 FRS Ultimate gokart daily; 16 Impreza sport hatch 2.slow for groceries |
| Clicking noise while idling | Smking0212 | Issues | Warranty | Recalls / TSB | 12 | 11-12-2020 01:52 AM |
| Car won't start no clicking noise | randomweather | Issues | Warranty | Recalls / TSB | 13 | 07-04-2020 05:30 PM |
| What is this OTHER clicking noise? | radroach | Issues | Warranty | Recalls / TSB | 0 | 02-16-2019 02:10 PM |
| Clicking noise in engine bay | teddydoggy | Issues | Warranty | Recalls / TSB | 4 | 08-12-2013 05:15 AM |
| Clicking noise? Not crickets... | Laika | Issues | Warranty | Recalls / TSB | 4 | 10-18-2012 07:39 PM |
