Old 03-09-2021, 01:22 PM   #15
ShackAttack
Drives: Blue BRZ Limited with PP
Originally Posted by A2TREJO View Post
How much does a tow hitch bike rack and 2 mountain bikes add up to in weight? If you have any exp on it please share. Is there any flex on the twin hitch factory tow points with the added weight? During speed bumps or uneven roads? When I was looking to buy the twin hitch with a quality bike rack, rack alone was 60lbs. 100lbs tongue weight limit of the twin hitch /:
Sent from my LM-V405 using Tapatalk
My bike is a little under 30 lbs and my single Kuat bike rack is in that same range. I went with a single bike rack as I had no need for two and didn't want to press my luck. The hitch is quite stable, but occasionally I have to tighten the hitch pin, as it loosens while driving and I don't want to lose my bike.
If I ever needed to haul a second bike, I figure I can get the extension plus another bike and be close to the hundred pounds limit.
Sent from my SM-N975U using Tapatalk
ShackAttack is offline   Reply With Quote
Old 03-10-2021, 12:37 AM   #16
soundman98
ProCrastinationConsultant
soundman98's Avatar
i've stood on the end of those bars in that first picture. all 200+ pounds of myself. it doesn't budge. but the suspension sagged a lot more!
NoHaveMSG (03-10-2021)
Old 03-10-2021, 09:42 AM   #17
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Yeah, I am not that concerned with Slambert's tongue weight recommendation when they say it is rated for 1000lbs towing. I'd imagine the loads it is designed for when accelerating, braking, and bouncing around with a 1000lb trailer are a lot less then 2 bikes and a rack at 120ish lbs.
soundman98 (03-11-2021)
Old 03-10-2021, 07:19 PM   #18
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
I took a drive from Little Rock to TN with a 32 lb bike on a 1up rack on the slambert hitch. It took quite a bit of abuse, and held up just fine.
Old 03-22-2021, 12:22 PM   #19
nartbeedham
Drives: 2015 Subaru BRZ
I have a brand new slambert twin hitch for sale if you are interested.
nartbeedham is offline   Reply With Quote
Old 03-27-2021, 09:01 AM   #20
gravitylover
I have a 1.25" receiver and transport 2 bikes on a hitch rack all the time. My e-bikes are not lightweights and I've never had a problem. I have at least 40k miles with bikes on the back of the car. Don't use a trunk rack, you will bend the trunk lid, it may not have happened yet but it will.
brz limited bicycle racks
VA Drivers -- Side Marker Question J1Avs Mid-Atlantic 12 06-01-2018 06:06 PM
other drivers mdm Other Vehicles & General Automotive Discussions 33 02-06-2016 11:38 PM
Gay FR-S/BRZ drivers Accurate Race Shop Other Vehicles & General Automotive Discussions 33 03-11-2013 03:02 PM
[GTA] BRZ/FRS drivers age chenshuo CANADA 3 12-05-2012 12:45 AM
Question for the experienced manual drivers.. enjoi23 Scion FR-S / Toyota 86 GT86 General Forum 54 10-18-2012 05:38 AM
