Old 03-01-2021, 01:30 PM   #1
JosephV
JosephV's Avatar
Drives: 96 4runner but going to buy an frs
Installing a subwoofer
So I was wondering what kind of subwoofers people here are using for their BRZ. I myself drive the 2020 TS model and was wondering if the car come prewired for a subwoofer since the dealership says they can install it in like an hour. I’m also curious if it’s worth getting the one sold by them or buying one to fit in that slot or even making the “box” myself to fit that space. Thanks I’m advance guys.
JosephV is offline   Reply With Quote
Old 03-01-2021, 02:34 PM   #2
soundman98
ProCrastinationConsultant
soundman98's Avatar
the one they sell is pre-made to fit, with plug-n-play harnesses. but it's mostly non-adjustable. the bass you get out of it is all you get, better or worse.
there is no pre-wiring for an aftermarket sub in the car.
Old 03-01-2021, 03:36 PM   #3
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
my first FRS had the upgraded headunit which came with RCA connections on the back, damn it was was so easy to hookup everything to my own amp/sub...I got the upgraded headunit on my 2nd FRS but they changed it so it no longer has the RCA ports so your only options are to get different HU or get some toyota wiring harness and connect through the wiring that goes to stock amp in the trunk..
this is how I hooked up mine..
HKz is offline   Reply With Quote
Old 03-01-2021, 04:19 PM   #4
JosephV
JosephV's Avatar
Thanks so it does seem like I would have to run my own cables to get an amp and sub in there since I don’t want to fork out the money for their own stock ones
Need help installing subwoofer with amp to oem HU and sound system (2016 FRS) Sonicp9 Electronics | Audio | NAV | Infotainment 15 08-12-2022 11:40 PM
Help!!! After installing Sony AX5000 my subwoofer barely works fatboydean Electronics | Audio | NAV | Infotainment 14 03-24-2021 08:23 AM
Subwoofer now available Opie Electronics | Audio | NAV | Infotainment 97 08-15-2015 09:23 PM
Door Unlocked dash light coming and going after installing subwoofer tbertran Electronics | Audio | NAV | Infotainment 0 01-01-2014 11:22 PM
[FR-S] Installing New Subwoofer and Mono Amp hx3 Electronics | Audio | NAV | Infotainment 0 08-09-2012 08:12 PM
