Old 08-02-2016, 07:56 PM   #267
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Originally Posted by Nah View Post
So from further testing of those 5 maps KoolBRZ kindly shared for me I have come to this conclusion.
Map 01 has the most power overall but a little too jumpy while cruising.
Map 05 had the smoothest downshift between 4-6k and was also the most linear map but lacked the top end power map 01 had. cruising was very easy.
Map 04 was a combination of the two.
Take a look at the maps and come to your own conclusion... im actually gonna combine both 01 and 05. ill use 01 maps from .85 and up and 05 from .8 down. Ill let you know how that goes.
however only the dyno will tell....
It's a little too soon to start mixing maps yet. The first step is to find the tune that starts making more noise than power. I sent you three more tunes, from 06 to 08, to try out as well. Those should be progressively worse. Let me know if they seem to get better as you go higher from 06 through 08.
If I say yes, will that make you think I understand?
KoolBRZ is offline   Reply With Quote
Old 08-02-2016, 08:05 PM   #268
ATaraxias
Drives: 1994 Geo Metro Hatchback
Originally Posted by KoolBRZ View Post
Here are 5 tunes based off of Wayno's "WW v109.2 2016-07-26 A01G" E85 RICH, Tune. I also included the LEAN tune, and the definition file I used to edit.
The only difference between them are the AVCS tables. I'm currently using the one equivalent to the 03 tune. You have 2 tunes with less valve overlap, and 2 tunes with more overlap than the overlap in tune 03. Load all 5 tunes in your OFT and try them all. Keep the one with the best power. If the best one is tune 01, or 05, than send me a PM for more tunes.
This is tuning by trial and error one digit at a time. You'd be surprised how different even 1 degree of change feels.
Quoting this because I have local access to E85 and a dyno tuner, suggestions on which one of the tables might pair best with the UEL OFH?
ATaraxias is offline   Reply With Quote
Old 08-02-2016, 09:28 PM   #269
Nah
Drives: 2013 Scion Frs 6mt
Use the last ones KoolBRZ put up I have a jdl uel header and it works great.
Nah is offline   Reply With Quote
Old 08-03-2016, 01:30 AM   #270
KoolBRZ
KoolBRZ's Avatar
Is your CAL ID A01C? If not, tell me your CAL ID and I'll make you a set. Right now I'm still trying to get the AVCS Intake and Exhaust spacing correct, so I don't have a good starting tune for E85 yet. The more people who work with these tunes, the faster I can come up with a universal starting tune for E85. A starting tune is close, but not perfect. The starting tune has all the large changes made, so that only small changes remain to perfect it to suit each individual car.
Old 08-03-2016, 02:50 PM   #271
ATaraxias
It is B01D. Thanks Kool.
Old 08-03-2016, 03:06 PM   #272
KoolBRZ
KoolBRZ's Avatar
E85 tunes
OK. I'll send you a PM with tunes and instructions.
Old 12-06-2016, 04:44 PM   #273
aagun
Drives: 86
bump
aagun is offline   Reply With Quote
Old 12-12-2016, 08:52 AM   #274
aagun
Drives: 86
from read this . ots is best(for the time) for NA engines .
spend days reading and reading this thread
maybe I will do same my own AVCS changes and have same experience on it
Old 02-28-2021, 12:39 PM   #275
pro_turbo
Drives:
Where are the dyno result then ? Should we back to shiv..? He is the one with proven dyno sheets
pro_turbo is offline   Reply With Quote
Timing chain issue? Hardpack Issues | Warranty | Recalls / TSB 14 01-11-2016 12:25 AM
AVCS failures? hmong337 Forced Induction 26 02-12-2015 04:01 PM
Stock Rom: Timing + Learn Value sw20kosh Software Tuning 7 12-11-2013 08:09 PM
E85, Boost and Ignition Timing jamesm Software Tuning 23 12-11-2013 03:19 PM
Timing belt shredded..?! drei CANADA 5 12-06-2013 06:54 PM
