Oxyg3n
Old 02-03-2021, 09:15 AM   #225
86prime
Drives: 18 BRZ tS
They already did the shims last time this happened. I wonder what can they do this time? More shims?
86prime is offline   Reply With Quote
Old 02-03-2021, 09:36 AM   #226
nitro_alltrac
nitro_alltrac's Avatar
Drives: '17 86
Did they flash the ECU last time? Mine is a '17 and that was part of the TSB for the '17s. Not sure about the later models.
It's possible that they may not have gotten all of the valve adjusted or maybe were off in their measurements and didn't get it shimmed correctly.
That was a worry I had in having Toyota techs dig into the Subaru engine.
Hopefully they can get it right this time.
nitro_alltrac is offline   Reply With Quote
The Following User Says Thank You to nitro_alltrac For This Useful Post:
86prime (02-10-2021)
Old 02-10-2021, 12:03 PM   #227
86prime
Drives: 18 BRZ tS
Brought the car into a different (better rated) dealership. Looks like they did NOT reflash the ECU last time. This is what was done this time:
Performed ECM software update
New CID - ZA1JN20C
Old CID - ZA1JN10C
Old 02-10-2021, 07:29 PM   #228
nitro_alltrac
Drives: '17 86
I think you'll see a difference now. Hopefully.
Help! From check engine light to fouled plugs back to check engine + plugs refouling larchamb Issues | Warranty | Recalls / TSB 44 04-03-2016 09:39 AM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 07:37 AM
Check Engine light on @5.7k miles and engine stalling at 4,000 rpms? djdrugga24 Issues | Warranty | Recalls / TSB 3 06-25-2014 06:06 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 06:16 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
