Old 02-04-2021, 10:46 PM   #1
Deathghat
Deathghat's Avatar
Drives: 92 civic, 13 brz
Metallic tinking noise/ hissing after headers and overpipe
Hey I just installed TOMEI UEL headers and Tomei Overpipe a few days ago, and I’m noticing a noise that sounds like an exhaust leak. I cannot figure out where it’s coming from or what it is, I was wondering if anyone else had this problem after installing thisUEL header Or another version with an overpipe after tuning.
The noise is very slight at idle but when I give it a little gas you can hear it, and when I’m cruising in low gears, low RPMS.
I have TOMEI UEL , TOMEI overpipe, invidia front pipe, and borla catback. All catless, tuned to stage 2+ with OFT. I’ve read a few forums stating that this is normal but I wanna hear other people’s thoughts. Thank you!
Deathghat is offline   Reply With Quote
Old 02-05-2021, 02:33 AM   #2
Purist
Purist's Avatar
Drives: Subaru BRZ
I had this exact thought aftrr my install.
This is the glorious sound of red hot exhaust gases streaming through stainless steel pipes.
Check for leaks to be sure but its just how they sound. Beautiful isnt it...
Sent from my SM-G973F using Tapatalk
Less More
Purist is offline   Reply With Quote
Old 02-09-2021, 09:28 AM   #3
euniqe
euniqe's Avatar
Drives: 2012 Toyota 86 GT
I have the pro speed racing uel header (basically an unbranded Tomei) and stainless overpipe and this has bothered me since the day I installed them. When I had my catback installed they assured me there was no leaks, another shop also confirmed it.
Unfortunately it appears its just a side-effect of having thin-wall stainless steel exhaust headers. For me, though, It does lessen the hotter the engine is. It's worst on cold starts.
euniqe is offline   Reply With Quote
The Following User Says Thank You to euniqe For This Useful Post:
Dzmitry (02-09-2021)
Old 02-09-2021, 01:42 PM   #4
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
Metallic TINKLING noise?
I would imagine it would sound something like what I would think THIS would sound like:
Definitely check for LEAKS!
My pubes are shaped like the number 86. There for I’m car. Derp
Count to muffens and call again.
I’m 40. So....... say hi to your sisters or daughters.
FR-S2GT86 is offline   Reply With Quote
The Following 2 Users Say Thank You to FR-S2GT86 For This Useful Post:
BrahmaBull1990 (02-17-2021), soundman98 (02-12-2021)
Old 02-09-2021, 01:58 PM   #5
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
I have the PSR headers and I don`t hear any difference from the stock headers(apart from rumble) Mine are wrapped and the collector has been tidied with a die grinder.
Old 02-09-2021, 08:41 PM   #6
Frankz54
Drives: 2019 Toyota GT86
I have the exact same setup. It's normal man. As long as you have no leak you will hear a metal sound coming from under the passenger side. Enjoy the ride
Frankz54 is offline   Reply With Quote
Old 02-10-2021, 09:36 PM   #7
Purist
Purist's Avatar
Drives: Subaru BRZ
Interesting about the collector. The exhaust guy that fitted ( did not supply) my PSRs was stunned at the quality and remarked on the collector. What was up with yours? Rough welding?
Less More
Old 02-12-2021, 04:48 AM   #8
gen3v8
gen3v8's Avatar
Drives: My18 wrxsti
I cleaned the inside of the casting. Nothing really wrong it`s just perfect now. No longer a casting but a finished piece. Put your finger inside yours and feel.
Old 02-19-2021, 09:34 AM   #9
FR-S2GT86
Master Collaborator
FR-S2GT86's Avatar
.........Put your finger inside yours and feel.
Jeez, if I had a nickel every time someone told me that.....
Old 02-19-2021, 10:41 AM   #10
Tokay444
How many headers did you install? Maybe that’s your problem. This car utilizes only one.
Old 02-19-2021, 11:07 AM   #11
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
I don't get ticking with my gruppe-s header but I get the wooshy thin wall steel piping sound on throttle. A thicker guage metal would solve that. I understand that open flash headers had thicker construction which would help mitigate that sound.
Interestingly a friend with a 14 FRS sold me his header and it had a ticky sound to it when installed. I don't hear anything like that on my 2017.
I wonder if that's more valve lash issue, and it's just valve train noise echoing into the exhaust?
Old 02-19-2021, 12:18 PM   #12
CB750F
CB750F's Avatar
Drives: 2015 BRZ WRB
I have Gruppe-S also but I did not notice 'more noise' but it's the thin walls according to this forum.... I came across similar post in 2013/2014/2015/2016...
CB750F is offline   Reply With Quote
Old 04-06-2021, 12:13 PM   #13
Mykii
Noodleking
Mykii's Avatar
Drives: 2013 Firestorm FRS
I've got the Skunk2 Alpha EL headers and theres a hell of a lot of tinking from 2.5k-3.5k Rpms in 6th gear. It appears for a quick second throughout the gears, but is super noticeable in 6th. Seemingly normal from what I've read, but it's kind of a sketchy sound..
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
Mykii is offline   Reply With Quote
exhaust, exhaust leak, headers, tinking
Hissing noise j_ros94 Forced Induction 7 10-07-2020 09:02 PM
Boosted brz hissing noise j_ros94 Issues | Warranty | Recalls / TSB 5 09-13-2020 02:40 PM
Metallic grind noise Vtplm Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-06-2019 04:05 AM
Hissing noise after turning off car Coop Issues | Warranty | Recalls / TSB 7 09-14-2018 02:28 PM
Hissing clutch noise FR-Sky Issues | Warranty | Recalls / TSB 32 02-16-2017 11:57 PM
