Old 03-17-2020, 09:41 PM   #1
Hardymason13
Drives: 2016 Scion Frs
Troubleshooting Exhaust Noise
Bought a Tomei UEL headers, over pipe, front pipe with invidia exhaust. After installing there is a metallic noise ticking during startup and through acceleration. Took it to the a shop and Toyota they had no response to this issue. Has anyone has this come up on their car?
Is it gaskets or turbulence in the headers
Hardymason13 is offline   Reply With Quote
The Following User Says Thank You to Hardymason13 For This Useful Post:
humfrz (03-18-2020)
Old 03-17-2020, 10:10 PM   #2
kev0
Drives: '14
Did you put in new gaskets when installing the header? If you did and there are confirmed no leaks..then it's just how the nature of the UEL is. The collector walls are thin which explains the metallic ticking noise.
kev0 is offline   Reply With Quote
Old 03-17-2020, 10:11 PM   #3
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
What you are hearing is likely the mechanical noises from the engine echoing in your new catless exhaust. If you look at the differences in construction from your Tomei vs your stock pipes it will be obvious. Check the alignment of the exhaust and the torque on every single bolt and nut from the engine header to the catback and tighten to be sure.
Howdy?! Welcome to the forum.
Intent > Content
Old 03-17-2020, 11:40 PM   #4
Hardymason13
Yeah all new gaskets and pieces.
Just looking through many videos and none of the cars have that sounds.
Old 03-18-2020, 12:48 AM   #5
I second the welcome to our forum -
Like mentioned, re-tighten all the exhaust system connectors.
Then, wait about two weeks, for the system to settle in (or for you to get used to it - ).
Old 03-18-2020, 02:57 PM   #6
deca
Drives: Halo 860
Hard to know without hearing your car in person, but I will say I notice the ticking noise with my header only in certain situations while driving and it doesn't really pick up in recordings. I was concerned about the sound shortly after installing my header but I've read enough identical accounts that I'm fairly certain it's just a normal sound. Unless it's crazy loud I wouldn't worry too much about it.
Also worth mentioning that the direct injectors make a pretty noticeable ticking noise after the car has been idling for a bit after starting up, and that sound is very prominent if you pop the hood.
deca is offline   Reply With Quote
Old 03-18-2020, 07:57 PM   #7
willburr
Drives: 2017 BRZ
Similar situation here. Tomei UEL and Q300. It's making an annoying tinny kind of noise under load that I never noticed in videos on YT. I haven't found any leaks. Hopefully it goes away or I find a leak.
willburr is offline   Reply With Quote
Old 03-19-2020, 07:10 PM   #8
Hardymason13
Yeah every YT vid never complained or talked about a different noise like that
Old 02-04-2021, 10:49 PM   #9
Deathghat
Deathghat's Avatar
Drives: 92 civic, 13 brz
Any update in this man? I’m exerpeincing the same issue and wondering if it’s just the sound of my header paired with full catless exhaust or if there’s a leak.
Deathghat is offline   Reply With Quote
Old 02-05-2021, 03:49 PM   #10
Tezzmeret
Tezzmeret's Avatar
Drives: 2014 Subaru BRZ
Going to piggyback off this thread because I'm having a similar issue. This one I was able to pick up in a video. Already confirmed I don't have an exhaust leak. Happens loudest when revving from 1k to 2k for a brief moment. It will happen on acceleration at all times and when not accelerating like engine braking it happens still but it's quieter. Not belts either, not anything hitting exhaust components. All I changed was the header and I'm using new gaskets to the head and from the header to overpipe.
Here is a video of it when revving.
Tezzmeret is offline   Reply With Quote
Old 02-05-2021, 03:53 PM   #11
Deathghat
Deathghat's Avatar
This is exactly how mine sounds, mines just louder
Old 02-05-2021, 03:55 PM   #12
Tezzmeret
Tezzmeret's Avatar
what header are you using? I've got a 1320 UEL header.
Big Brake Kit Troubleshooting help. N1rve Issues | Warranty | Recalls / TSB 19 09-04-2018 11:28 PM
BRZ DRL Troubleshooting MaximaZero Issues | Warranty | Recalls / TSB 2 11-17-2015 04:31 AM
Troubleshooting with a KW c38 pgranberg11 Forced Induction 7 10-13-2015 08:05 AM
Need troubleshooting help. Camop82 Scion FR-S / Toyota 86 GT86 General Forum 6 10-14-2013 02:16 AM
Start up troubleshooting. Gost Other Vehicles & General Automotive Discussions 12 01-09-2011 06:45 PM
