Old 01-29-2021, 03:33 PM   #15
Hamza
Hamza's Avatar
Drives: Widebody 86/F56 Mini Cooper S
Originally Posted by EndlessAzure View Post
@Hamza Does the installation manual have a reference on how to set-up the preload and height adjustment collars to factory recommendation? If there are, it will also tell you where the car will sit relative to stock when set-up according to the recommendation. This will be part of the total drop the coils are capable of.
Then, you can adjust from there using the lever ratio (1:1 in the front, 1:1.3 in the rear)
These coils don't have preload, and the recommended height was pretty much identical to stock. I think I have the rear figured out now tbh, cause I'm somewhat content with it and it's rubbing on the inner fendor (there's a widebody on). Should I just trim the inner fendor more?
Hamza is offline   Reply With Quote
lowering without aftermarket rear control arms littlealex Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 11-26-2019 03:53 PM
Toyota 86/Scion FR-S TRD Lowering Springs & TRD Sway Bar Kit -Front and Rear burgeralert Brakes, Suspension, Chassis 5 03-28-2019 11:16 PM
Uneven rear camber after lowering springs Euphues Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 11-11-2015 09:27 PM
Any way to lower rear lowering springs further? BlueDubbinTDI Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 02-03-2014 10:03 PM
Rear camber after lowering mike_ekim1024 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-09-2013 05:01 AM
