Drives: Widebody 86/F56 Mini Cooper S
Need Help with Rear Coilovers
Hey so I'm a new member here. I have a 2013 gt86.
Basically I decided to go at swapping out my stock (old owner chopped springs) with Tein advance Z's. All went well but on the rear I'm stuck on the final bolt. On the driver's side I cannot at all match up the inner most bolt (one most towards the center of the car) of the control arm to where it's supposed to bolt in. I've tried pulling the rotor, where it budges but there's still about 1 mm of space needed for the bolt to fit. I've tried both increasing and decreasing load on the coil. But nothing is getting the holes to align. I'd attach a picture but this is my first post and kinda confused how to to do that :*) Any help would be very appreciated as I've spent an embarrassing amount of time trying to get this one bolt. |
#2 |
AutoX-10/10ths every run
I'd suggest unbolting the coilover mounting bolt from the lower control arm. Then get the lower control arm bolt (the one you are having issues with) into the subframe. Once you've got all of the suspension pieces bolted up, use a floor jack under the wheel knuckle to move the suspension into place so that you can re-install the coilover mounting bolt into the lower control arm.
#3 | |
#4 |
Alright update, I'm not sure if I somehow missed it in the diys but releasing the hand brake worked and the bolt slid right in. Quite frustrated I spent a good 5 hours on 2 minutes of work.
#5 |
Drives: 2018 BRZ
Yeah, I've had the same frustration doing some transmission and diff bushings. Always remember to release the handbrake and put the transmission in neutral after lifting the car.
| Tags |
| coilovers, gt86, help needed |
| WTB: ST/KW coilovers rear springs | trueno86power | Want-To-Buy Requests | 3 | 05-16-2020 11:22 AM |
| Do rear coilovers have a left and right? | dstrout | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 08-09-2018 12:03 AM |
| Pbm coilovers not low in rear? | Brzxton | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 40 | 04-11-2018 09:02 PM |
| Can't Get Rear Coilovers Off? | 636 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 07-28-2015 01:59 PM |
| Noise in the Rear with ST Coilovers | DemonRawr | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 05-01-2015 10:21 PM |
