Old 12-26-2020, 04:10 PM   #15
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Those rates seem pretty excessive. I'd drop down to 400lb springs F&R to start. Maybe go to adjustable swaybars and use those, and damping adjustments to dial in the balance of the car.
Old 12-26-2020, 04:17 PM   #16
supercharged680
Drives: 2015 GT3 , 2018 BRZ , 2007 S2K
Originally Posted by DarkPira7e View Post
Totally understandable.
Have you let them know your complaints? Certainly they should be able to provide support for how you'd like the response of your coilover to be.
With that said- driving style is completely unique in some regards.
Imagione if you said " I want a FAST CAR" and someone gave you a big huge ass laggy turbo car with 900WHP. Ok, yeah, it's FAST. But you meant " I want to accelerate extremely quickly" so a small set of twin turbos or a supercharger would work better. or maybe a V8 engine swap?
My point being- they aren't completely at fault; how much have you exhausted the adjustability of the coilovers you received? They may respond much more favorably with a different ride height or rebound setting.
I'm not a guru, just an observer; I still think your bets chance for help lies within their support model. If it's an ineffective system, return them and make another purchase elsewhere
Thanks!
Yes you are right, they did help me interms of alignment settings and the car tire wear with a pyrometer was perfect and on point.
They have given me the ride height which i am using at the moment , 2 mm lower than where i had it ( nothing has changed )
Settings , 1 click does not make a difference even 2 or 3 , something is definitely wrong with this.
lets compare 2 different settings , theirs and mine.
Their setting
F Compression 6
F Rebound 10
R Compression 6
R Rebound 8
My settings
F Compression 1
F Rebound 6
R Compression 2
R Rebound 6
I have had 7 tenths quicker in a mid 1 minute track on my settings.
Last but not least , the car is bouncy in the front only which is a vague term whenever i have someone ride with me someone says its too stiff others say yes its bouncy because its soft. Very difficult to say.
What i feel is the front reacts differently from the rear on a given road surface or bump + series of bumps.
When i get 1 big bump or ride a curb its perfect, however multiple bumps the car has an excessive pitch in the front like it cannot absorb all the damping.
I have a feeling its a valving issue but how is it possible to prove to a " high end coilover manufacture " when their answer is " we have never had this problem before "
supercharged680 is offline   Reply With Quote
Old 12-27-2020, 04:30 AM   #17
marco_mc22
Drives: Toyota 86
I would try softer springs, something like 8k 10k (450, 550), anyway never heard good reviews about those tires, I would use Direzza, 71r or PSC2 instead
marco_mc22 is offline   Reply With Quote
Old 12-27-2020, 03:36 PM   #18
norcalpb
norcalpb's Avatar
Originally Posted by supercharged680 View Post
I am using Nankang NS2R 235/45 R17
Car only has the coilovers, nothing else.
Kind of a tall sidewall size, no? I run 235/40 R17 on 200tw tires to keep the tire/wheel height similar to stock.
Old 12-29-2020, 11:29 AM   #19
Icecreamtruk
Drives: Track preped NA FRS
Your spring rates are not too stiff, but it does seem like you bought european and/or japanese coilovers that are meant to run on butter smooth surfaces/track and only hit a curb once in a while (and a mild curb at that), but are running rather bumpy racetracks. Thats an important detail when choosing coilovers that a lot of people skip over. My wild guess would be that you got JRZs? I've ridden on one car with their pro1 here and on a bumpy track, they did not feel better than my way cheaper "taiwan rebrand" (as some like to call them) coilovers.
One thing though, you havent provided any video, and this might help. Some coilovers feel like the car is bouncing all over the place and that you would spin out if you stepped hard on it on corner exit or that it would understeer madly if you entered the corner faster, but is it actually the case? What you feel from a bounce indicates what the chassis is doing, but if your tires are keeping contact with the road it might not affect traction/balance as much as you think.
Quick edit: no way in hell a coilover alone is responsible for 3sec a lap on a 1min track on the same tires. My guess is that you are underdriving the car because you do not trust how it feels, and are driving much more assertive on the porsche since you do like how it feels.
Icecreamtruk is offline   Reply With Quote
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
CSG Mike (12-29-2020), supercharged680 (12-29-2020)
Old 12-29-2020, 03:11 PM   #20
CSG Mike
CSG Mike's Avatar
Your tire grip level and chosen spring rates are completely mismatched.
Try using a tire designed for the type of spring rates you've chosen, or lower the spring rate to match the tire.
Pitch, squat, and roll are not detracting from grip, and can be exploited. Look at how much body roll F1 cars have, when they have THAT much downforce and THAT little weight.
Old 12-29-2020, 03:13 PM   #21
CSG Mike
CSG Mike's Avatar
Thanks!
Their setting
F Compression 6
F Rebound 10
R Compression 6
R Rebound 8
My settings
F Compression 1
F Rebound 6
R Compression 2
R Rebound 6
Your settings lead me to believe that you like what you'er familiar with. Your type of setting, guessing based on the 3 letter name (of which there are several), will likely result in jacking, which is why the front feels vague and bouncy.
Have you considered hiring a local pro to dial in your dampers to the best of what is available within the current equipment?
I agree; something is not right with your setup.
Old 12-29-2020, 04:15 PM   #22
supercharged680
I do not think the tire would do that 200 TW vs 100 TW , i highly doubt
Old 12-29-2020, 04:22 PM   #23
supercharged680
Hitting 1 big curb is fine however the car has excessive pitch at low speed compression is what i came to find.
The best setting on the road for it to ride ok but still very jerky , Max compression and lowest rebound.
Video attached, you can see how the car tends to lose grip , i am under driving the car indeed as you said because it does not have a clear tendency , it understeers or oversteers on the same corner and input.
Old 12-29-2020, 04:23 PM   #24
supercharged680
Unfortunately there are no local pros here.
Video uploaded, look what it does on the smooth long straight and how it suddenly loses grip
Old 12-29-2020, 05:07 PM   #25
supercharged680
Sorry i mistyped the tire size, it is a 235/40 R17
The Following User Says Thank You to supercharged680 For This Useful Post:
norcalpb (12-29-2020)
Old 12-29-2020, 08:03 PM   #26
CSG Mike
CSG Mike's Avatar
If you gauge tires by TW, you are unfortunately mistaken. Gauge the tire by its grip, not by its wear.
Grady (12-30-2020)
Old 12-29-2020, 08:06 PM   #27
CSG Mike
CSG Mike's Avatar
All I can see is a very bouncy, very pushy car. I can't "see" pitch, because the car is bouncing so much.
Try backing all settings off to minimum, and see how it behaves.
Consider flying in a qualified pro to test and set up the car.
Icecreamtruk (12-30-2020)
Old 12-30-2020, 02:47 AM   #28
supercharged680
I have done that,
Their setting
F Compression 6
F Rebound 10
R Compression 6
R Rebound 8
My settings
F Compression 1
F Rebound 6
R Compression 2
R Rebound 6
I felt more confident pushing the car but its still not where i want it to be, i will be uploading a video of me driving a GT86 cup running Tein SRC suspension and the car felt GREAT!
I don't understand coilover spring rates. Spacemane969 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 46 10-10-2019 09:57 PM
Spring Rates Student Driver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 08-08-2017 11:57 AM
Coilover Spring Rates - Help Needed! Hentai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-22-2016 12:52 PM
WTB: Toe arms & Coilover (ATLEAST 10k spring rates ) DavidBob Want-To-Buy Requests 0 10-31-2016 11:40 AM
Coilover spring rates for comfort Barbecue Suspension | Chassis | Brakes -- Sponsored by 949 Racing 35 12-12-2013 11:09 PM
