#393 | |
BRZ vs S2000 vs Cayman S (my take)
The 0W-20 really is just an EPA thing. Almost all cars use it these days. It’s not some dramatic change in the engine. A lot of people run heavier weight in the FA20. Someone posted the spec sheet for the factory 86 race car and it has some info on oil weights and if I recall 50W was one of the options. Let me see if I can dig it back up. Okay the TMG CS-Cup manual says 10W-60 Last edited by ermax; 12-18-2020 at 09:08 PM. |
#394 |
Drives: '23 BRZ
50 or 60wt should be fine track-only with oil temps at 270F. I wouldn't run that for mostly-street with some track time though...
#395 |
Looks like we all just sell our cars and get Hyundai’s. This way if we miss a shift or just feel like bouncing off the rev limiter all day at the track and our engine or tranny blows, we can get it replaced under warranty. I wonder how many they would warranty for me in 10 years of tracking? I mean I get it they have no issues now, but 10 years is a long time.
You never know. It’s possible. Even Subaru warrantied some engines from cars they knew were tracked, it depended on the dealership. That ended fast though with all the EJ issues. Don’t bother responding, I’ll be on the Hyundai forum. �� Back from the Hyundai world. See link. https://tiremeetsroad.com/2019/05/28...ur-veloster-n/ It says it in warranty, but still says normal use. Should be interesting to see if they actually honor it. Lots of easy ways to say it was not normal use. Time will tell. Last edited by Ernest72; 12-20-2020 at 08:09 PM. |
#396 | |
Drives: 2015 FRS
Meanwhile Toyota can't develop a sports car for the North American market that has one of their own engines in it because "reasons". |
#397 | |
#398 |
Anti stance.
#399 |
#400 |
Anti stance.
#401 |
#402 |
Drives: 2013 FR-S Argento
#403 |
Drives: AP2 S2000, 91 Miata 1.8L Rotrex 5MT
That man will literally argue any point, regardless of being clearly wrong, to death. Just gotta throw in the towel sometimes
2022 Hyundai Elantra N 6MT SCCA TT S3//Will be back in an 86 eventually
#404 |
Anti stance.
You honestly believe the service interval is reduced because of equal parts track use and equal parts heavier oil?
You can run much more viscous oils without reducing the service interval, if you’re not tracking the car. In fact, in many cases, you can increase the service interval. The intelligent thing to do would be to run UOAs and adjust the service life accordingly. I’ll go so far as to ask, what do you think the service interval of the Cup car would be if it ran factory fill? Haven’t been wrong yet. Last edited by Tokay444; 12-22-2020 at 05:47 AM. |
#405 |
So you think running 10W-60 is the cause of the short intervals? Come on man, it’s a race car. If you ran 0w-20 in it, it would have even shorter intervals. My whole point is the 0W-20 isn’t used because of some dramatically different tolerances. It’s about economy in a “daily driver”. On track there are better options. |
#406 | |
https://www.google.com/amp/s/blog.am...ty-of-oil/amp/ Basically supports both general ideas that: A) modern motors are often designed for lower viscosity oils, indeed designed that way for EPA regulations And B) you shouldn't use any old weight you choose and ignore that design. Thicker oil has a harder time flowing through tight bearing journals etc. It really depends on tolerances in the motor. Maybe the FA20 tolerances aren't that tight? Maybe they are but per Mike's contribution the fact that the oil cannot support flow/heat transfer as well as the lower viscosity oils is secondary to maintaining higher oil pressure during extended track runs - speculating here as I don't participate in any cup series, Mike may have a better idea about the real reason. It is actually interesting stuff, thicker oils provide a thicker film capable of supporting greater loads (think oil supported journal bearings) but another way to support high loads/force is to use very tight tolerance bearings with thinner oils. Anyways this appears to be religious, so I'll just leave it as my personal opinion instead of fact ![]() Sent from my SM-G965U using Tapatalk Last edited by bfrank1972; 12-22-2020 at 09:08 AM. |
| Tags |
| brz, cayman, s2000 |
| 2013 981 Cayman | ironchef | Other Vehicles & General Automotive Discussions | 49 | 12-09-2012 07:03 PM |
| FR-S vs Cayman | colganc | FR-S / BRZ vs.... | 102 | 09-13-2012 04:17 PM |
| GT86 vs. 370 vs. Cayman S | wrxgoose | FR-S / BRZ vs.... | 0 | 08-27-2012 11:26 PM |
| FRS/brz VS Porsche Cayman | jurjurson | FR-S / BRZ vs.... | 22 | 08-15-2012 04:14 PM |
| FR-S, Cayman S, & Lexus GS | Mcdj18 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 17 | 06-23-2012 04:49 PM |
