Old 12-18-2020, 05:40 AM   #1
golemslord
Drives: 2014 White FRS
Camber without rubbing? TRD springs
Hello,
Currently have TRD springs for almost 3 years now. Haven't done any adjustments to camber (all natural from the 1 inch drop) (rear has visible neg camber and front has almost none).
I notice there are some slight understeer during spirited drives. What are my options to increase "stability" around corners?
I was looking into adding camber bolts at the front to get some negative camber but worried it might rub stock spring perch. 18x9.5+35 with 245/35/18 Falken Azenis FK510
Anyone have similar setup that made it work? or any other suggestions to increase handling for TRD springs?
Thanks
golemslord is offline   Reply With Quote
Old 12-18-2020, 05:56 AM   #2
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Get your toe checked.
The Following User Says Thank You to x808drifter For This Useful Post:
DarkPira7e (12-18-2020)
Old 12-18-2020, 11:44 AM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
With those wheels/tires and big stock-diameter springs you're not going to get much/anything with camber bolts. I went with camber plates but they robbed me of bump travel, no bueno with stock struts (I ltimately went with Bilsteins which have a ton more usable bump travel).
Offset top mounts might be your best bet to get some desperately-needed front camber:
https://www.ftspeed.com/part/580096-...B#.X9zN2thKhPY
golemslord (12-19-2020)
Old 12-18-2020, 12:42 PM   #4
churchx
churchx's Avatar
Drives: 2014 GT86
Also take note that in ZDan's link "only 1 left" and they are sold separate, one needs two.
Old 12-18-2020, 03:01 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
This, a good shop can probably get you to -1.5 or maybe even a bit more but that's probably about it. That'll still be better then stock.
ineedyourdiddly
Old 12-18-2020, 03:49 PM   #6
Drifter X
Drifter X's Avatar
Drives: 2019 Toyota 86 TRD SE
https://www.rallysportdirect.com/par...nt-strut-mount
Looks like only 1 left here too. I have these with SACHs. I love them.
Drifter X is offline   Reply With Quote
Old 12-18-2020, 06:04 PM   #7
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
+1 for the pedders mounts.
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
marco_mc22 (12-19-2020)
Old 12-20-2020, 11:02 PM   #8
jflogerzi
jflogerzi's Avatar
I was able to get -2.3 of camber in the front with crash bolts and peddlers top mounts. Wheels and tires are 17x8 and 245-40-17
2013 Series 10 FRS #553
Old 12-21-2020, 12:56 PM   #9
gtpvette
Drives: 2015 FRS - FFR GTM
How do camber plates reduce bump travel??
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 12-21-2020, 01:52 PM   #10
Drifter X
Drifter X's Avatar
Camber plates are shorter (flatter or thinner) than oem strut mounts.
Old 12-21-2020, 02:54 PM   #11
steverife
Drives: 2016 Scion FRS
The SSC kits get you more than -3 degrees from camber with Eibach Pro Plus springs and SPC camber bolts. That is a 17x8 wheel, et40. You might get less camber before you put your wheel into your strut with an 9.5" wheel, but you should still be able to get plenty of camber.
With that said, I can't really imagine the car not understeering with Falken FK510's. You just aren't going to have a lot of front grip.
steverife is offline   Reply With Quote
Old 12-21-2020, 03:04 PM   #12
strat61caster
Koni yellow have a bigger upper hole that oe struts don't have for that little extra camber. Without it and with the spc+oe bolts best you'll do is -2.5 ish iirc. I think you're underestimating how much less camber you get with a 1.5" wider wheel, even 5mm offset (45et) is a few tenths less camber on the ssc package and you can't hit -3.0°
ineedyourdiddly
Old 12-21-2020, 03:16 PM   #13
steverife
I thought only the "first run" Konis had the larger hole. I also had different experiences as far as what you could fit with the SSC setup, but...
Regardless, I would define anywhere from about -1.5 and up, as plenty. Camber plates are overkill for this application, IMO.
Old 12-21-2020, 04:00 PM   #14
strat61caster
To my knowledge they still supply a centering washer to meet SCCA-Street compliance, and it might only be on request these days, you definitely cannot hit -3 with two camber bolts and factory struts, I've tried which leads me to believe the SSC kit still has the enlarged hole, I only got around -2.2 iirc and I've read similar claims around here. Maybe they based their design off a WRX/STI that has a factory cam bolt, not sure. Should be easy enough to measure if you ever have the need to unbolt that strut, just compare the diameter of the two upper holes, if they match it's not OE spec.
For this application 'spirited drives' I would agree, -1.5 to -2 should be a nice improvement over stock with minimal adverse affects.
ineedyourdiddly
FS: NiB Lowering Springs and Camber Bolts Gloonge Brakes, Suspension, Chassis 2 06-17-2020 12:49 PM
Widest wheels without rubbing on stock springs with eibach springs ? H214M Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 10-09-2017 12:41 PM
TRD Springs,, Camber kit , Shocks? phongtphan21 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-18-2015 03:48 AM
TRD Lowering Springs Camber. ChrisP Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 10-26-2015 03:21 PM
RS*R Super Down springs/Camber Bolts troek Brakes, Suspension, Chassis 2 12-25-2014 03:18 AM
