Drives: 2014 White FRS
Camber without rubbing? TRD springs
Hello,
Currently have TRD springs for almost 3 years now. Haven't done any adjustments to camber (all natural from the 1 inch drop) (rear has visible neg camber and front has almost none). I notice there are some slight understeer during spirited drives. What are my options to increase "stability" around corners? I was looking into adding camber bolts at the front to get some negative camber but worried it might rub stock spring perch. 18x9.5+35 with 245/35/18 Falken Azenis FK510 Anyone have similar setup that made it work? or any other suggestions to increase handling for TRD springs? Thanks |
#2 |
LMGTFY
Drives: 13 FRS, 91 Miata
Get your toe checked.
| The Following User Says Thank You to x808drifter For This Useful Post: | DarkPira7e (12-18-2020) |
#3 |
Drives: '23 BRZ
With those wheels/tires and big stock-diameter springs you're not going to get much/anything with camber bolts. I went with camber plates but they robbed me of bump travel, no bueno with stock struts (I ltimately went with Bilsteins which have a ton more usable bump travel).
Offset top mounts might be your best bet to get some desperately-needed front camber: https://www.ftspeed.com/part/580096-...B#.X9zN2thKhPY |
| The Following User Says Thank You to ZDan For This Useful Post: | golemslord (12-19-2020) |
#4 |
Drives: 2014 GT86
Also take note that in ZDan's link "only 1 left" and they are sold separate, one needs two.
#5 |
Drives: '13 FRS - STX
This, a good shop can probably get you to -1.5 or maybe even a bit more but that's probably about it. That'll still be better then stock.
| The Following User Says Thank You to strat61caster For This Useful Post: | golemslord (12-19-2020) |
#6 |
Drives: 2019 Toyota 86 TRD SE
https://www.rallysportdirect.com/par...nt-strut-mount
Looks like only 1 left here too. I have these with SACHs. I love them. Sent from my iPhone using Tapatalk |
#7 |
Just the tip
Drives: 2017 DGM BRZ
+1 for the pedders mounts.
| The Following User Says Thank You to wolffbite For This Useful Post: | marco_mc22 (12-19-2020) |
#8 |
I was able to get -2.3 of camber in the front with crash bolts and peddlers top mounts. Wheels and tires are 17x8 and 245-40-17
2013 Series 10 FRS #553
#9 |
Drives: 2015 FRS - FFR GTM
How do camber plates reduce bump travel??
2015 FR-S - One Day I'll Finish The Swap |
#10 |
Camber plates are shorter (flatter or thinner) than oem strut mounts.
#11 |
Drives: 2016 Scion FRS
The SSC kits get you more than -3 degrees from camber with Eibach Pro Plus springs and SPC camber bolts. That is a 17x8 wheel, et40. You might get less camber before you put your wheel into your strut with an 9.5" wheel, but you should still be able to get plenty of camber.
With that said, I can't really imagine the car not understeering with Falken FK510's. You just aren't going to have a lot of front grip. |
#12 | |
#13 | |
Regardless, I would define anywhere from about -1.5 and up, as plenty. Camber plates are overkill for this application, IMO. |
#14 | |
For this application 'spirited drives' I would agree, -1.5 to -2 should be a nice improvement over stock with minimal adverse affects. |
| FS: NiB Lowering Springs and Camber Bolts | Gloonge | Brakes, Suspension, Chassis | 2 | 06-17-2020 12:49 PM |
| Widest wheels without rubbing on stock springs with eibach springs ? | H214M | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-09-2017 12:41 PM |
| TRD Springs,, Camber kit , Shocks? | phongtphan21 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-18-2015 03:48 AM |
| TRD Lowering Springs Camber. | ChrisP | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 10-26-2015 03:21 PM |
| RS*R Super Down springs/Camber Bolts | troek | Brakes, Suspension, Chassis | 2 | 12-25-2014 03:18 AM |
