Old 11-21-2020, 01:00 PM   #1
snuff58
snuff58's Avatar
Drives: 2014 Subaru BRZ Limited MTblue
Spoiler / wickerbill
Well, I believe I've come to the point in my tracking adventure that I am researching aero: adding a splitter and spoiler (not a wing) and maybe rear diffuser.
Looking for others'experiences, recommendations, warnings, etc.
Planning on making the splitter.
Looking for a spoiler just large enough to be able to add an adjustable strip to it's rear surface.
MY14 BRZ
Sent from my moto g power using Tapatalk
snuff58 is offline   Reply With Quote
Old 11-21-2020, 01:20 PM   #2
norcalpb
norcalpb's Avatar
Here are a couple I like:
Old 11-21-2020, 01:32 PM   #3
snuff58
snuff58's Avatar
norcalpb
Thanks.
The first looks too narrow. What's the second one? I like the last two.
Old 11-21-2020, 02:27 PM   #4
norcalpb
norcalpb's Avatar
Originally Posted by snuff58 View Post
norcalpb
Thanks.
Second one is Perrin.
Verus was nice enough to do some virtual air flow testing on it:
https://www.verus-engineering.com/bl...ap-analysis-31
I’m iffy on it because it may produce a ton of drag at high speed, which our little engines don’t like. But real world application can always differ.
Old 11-21-2020, 02:49 PM   #5
snuff58
snuff58's Avatar
norcalpb
Not the Perrin unit, it mounts on the OE spoiler. I will remove my OE spoiler.
Old 11-21-2020, 02:54 PM   #6
snuff58
snuff58's Avatar
norcalpb
I can't find the second one (no name or logo) as Perrin. Would it mount directly on the back of the trunk lid?
Old 11-21-2020, 02:58 PM   #7
snuff58
snuff58's Avatar
The Perrin unit that mounts on the OE spoiler is listed as DISCONTINUED on 86speed website.
Old 11-21-2020, 07:06 PM   #8
norcalpb
norcalpb's Avatar
norcalpb
norcalpb
Well would you look at that, it is finally a discontinued product. And no I don't think it would fit without the stock spoiler like it is intended to be.
You can also try your hand in making your own, similar to this:
Old 11-21-2020, 08:20 PM   #9
snuff58
snuff58's Avatar
norcalpb
I think I'll look for a low profile unit to mount on the lid that will allow me to add a strip to it's back
Old 11-22-2020, 02:56 AM   #10
RayRay88
Drives: 2017 86 860 Special Edition
949 Racing project car:
RayRay88 is offline   Reply With Quote
Old 11-23-2020, 12:53 PM   #11
M0nk3y
Why are you so against adding a rear wing element?
Spoilers like the 949Racing car result in a high drag effect as a results of a massive wake zone immediately behind the element itself.
My Versus front splitter + UCW Rear Wing at 6* AOA resulted in 2 mph less VMax at Mid-Ohio (122 vs 120 mph) into China Beach and still was ~1.5 seconds faster on the same tire same conditions.
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post:
strat61caster (11-23-2020)
Old 11-23-2020, 04:55 PM   #12
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
You just made me realize that an adjustable rear wing could be moved to a lower drag config for the drive home because mpg because I'm driving this car Monday morning too...
ineedyourdiddly
Old 11-23-2020, 05:05 PM   #13
M0nk3y
Right, when I tow my car I throw my wing back to 0 AOA. I haven't really noticed any MPG hit on the towing aspect. DDing around back and forth to work (35 mph roads 10 miles total) I still get 28-29 MPG. Nothing abnormal.
Those type of spoilers do great at low speed (think all Street Prepared style classes). Anything above 60+ you're going to see a massive negative impact
Kyle H. - #89 STX
Old 11-23-2020, 05:59 PM   #14
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
The drag from it is not bad. I have had one for years.
That is what I am planning to do with my GTC200. The drag from it is bad at minimum AOA. Going to build custom mounts with more adjustment.
norcalpb (11-23-2020)
Will TRD style spoiler cover stock spoiler holes? jRuN Cosmetic Modification (Interior/Exterior/Lighting) 2 07-31-2018 09:49 PM
Battle Aero Swan Neck Spoiler Paired W/ Rocket Bunny V2 Duck Bill Spoiler Preppy Cosmetic Modification (Interior/Exterior/Lighting) 30 02-10-2017 10:20 PM
BRZ Limited Spoiler. Is their any spoiler that uses the stock spoiler holes? FR-Sizzle Cosmetic Modification (Interior/Exterior/Lighting) 10 09-21-2015 03:29 PM
FS OEM BRZ Whiteout Spoiler or Trade for Rear Lip or Duckbill Spoiler Tripp1117 Exterior Parts (Aero, Lighting, Etc.) 1 07-11-2014 04:58 AM
Special: FRS/BRZ TRD & Stivo spoiler hybrid Spoiler design JonMotoring Groupbuys 22 06-23-2014 03:03 PM
