#29 | |
Drives: TBA
https://www.toyota.com/owners/resour...als/camry/2017 Where did you get the new battery? If it was from an auto parts store, it's probably been on the shelf wet charged for months and may need recharging or is defective. That usually isn't an issue at Toyota dealers, they go through so many that most have been on the shelf for a month or less. If it's an aftermarket battery with a return policy, consider doing that then get a fresh battery from a Toyota dealer, they're on sale this month and if that doesn't work, it will buy you some good will if your car winds up at a Toyota dealership for repair. |
| The Following User Says Thank You to Atmo For This Useful Post: | Toyota. (11-17-2020) |
#30 | |
#31 |
Drives: (2017) Toyota 86 / 860 / Halo White
Gonna try a bunch of things this evening when I get off work. Unfortunately I work until 8 PM, so I don't have much time to work on it and no sunlight lol. Gonna replace keyfob battery, clean and retighten battery connections, attempt to turn wheel as I'm also reading that a wheel lock can inhibit a start, etc.
#32 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | Toyota. (11-17-2020) |
#33 |
Drives: 2013 frs red
Sounds like battery
| The Following User Says Thank You to Lantanafrs2 For This Useful Post: | Toyota. (11-17-2020) |
#34 |
Gave it another go during my lunch break. No luck. Definitely appears to be an electronic/battery issue. Windows, Headlights, Interior Light, Door locks and such don't work. The dash lights up and continually beeps at me. Showing multiple errors (Power Steering error, Break Error, etc.) Press in break and attempt to start the vehicle and it does absolutely nothing. Just tells me to press in the break and hit the start button. Getting pretty sick of screwing with it as I have limited time and am a long shot from a mechanic. Probably just gonna try and get it towed if possible (parked in a really awful spot and car won't go into neutral) so not sure how that's gonna work.
#35 |
30 minute maintenance
Drives: My18 wrxsti
Park release.
https://www.ft86club.com/forums/show....php?p=1831458 |
| The Following User Says Thank You to gen3v8 For This Useful Post: | Toyota. (11-17-2020) |
#36 | |
#37 | |
#38 |
#39 |
I didn't know you replaced the battery. Check terminals are snug.
Unless you have a fuse out that's throwing things off? |
#40 |
Señor Member
I haven't searched for your other threads so apologies if these have been eliminated already. Have you checked the connections at the solenoid? Are they tight and clean? Have you checked the ECU for error codes? Have you got the battery connected with the correct polarity? Do we have a fusable link that might have blown? Did you try tapping the solenoid in case it is sticky?
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | Toyota. (11-17-2020) |
#41 | |
| The Following User Says Thank You to Toyota. For This Useful Post: | Turdinator (11-17-2020) |
#42 |
| LED Changed Dual Climate A/C Start Stop Button 2017 LCD Cluster Traction Controls! | JNuman85 | Interior Parts (Incl. Lighting) | 0 | 04-03-2020 05:01 PM |
| Help! Is there anyway to change the 2017 cluster start up image? | slashlee | DIY (Do-It-Yourself) Guides | 2 | 11-17-2018 06:36 PM |
| 2017 CHRYSLER PACIFICA MINIVAN VS 2017 TOYOTA 86 WHO WINS IN A DRAG RACE??? | Extreme Dimensions | Off-Topic Lounge [WARNING: NO POLITICS] | 6 | 06-08-2017 09:59 AM |
